Tow hooks for the Lx2610
RichardAaronlx2610
Aug 3, 2021
454
522
New Jersey
Not sure if this has been posted before. But I got the KBOH rear John Deere tie down hooks and mounted them on the front of the Lx2610 and they fit beautifully. Just had to get some 1/2” hardware. C26C69CD-09F9-4017-A715-68E53A760BDE.jpeg 4F70ACF7-7DA3-4E8C-90DF-6E522A4812CC.jpeg 6F9EC725-062C-42C6-9A92-1169E4A6F522.jpeg 26934F02-3929-4CB1-A891-6ABA502EFA62.jpeg BB27DB39-7032-414F-BC54-7675C45830C9.jpeg 5D6352AD-EB84-4652-A6C0-7D1D571F11ED.jpeg 4219D4C9-AAE3-4B31-8AAE-00D5EEC14F1A.jpeg
Reactions: 14 users
TX Chris
MX5400, BH92, RTV900, ZD326
Dec 14, 2020
150
132
Rowlett, TX
Thanks for posting this. I found the 5 eleven designs hooks a while back but couldn't come to terms with $150 for two hooks.
I'm going to scout the MX5400 and see where I can find front and rear that would accommodate these hooks.
I'm still baffled that Kubota doesn't provide a single tie down point on any of their lighter duty equipment. From tractors to mowers to RTV's. I guess they assume we'll never move them or take them to the dealer for service.
5,164
What is even more surprising is that none of the aftermarket people haven't stamped out tie-down hooks that are drilled for specific machines at a reasonable price. I see a lot of items where it appears that the sellers are trying to get wealthy on every sale, rather than making smaller profits on each item and selling them in volume. Unfortunately, even Kubota operates on this principle. Today I looked up the price of the rear windshield wiper motor on the Messicks website, and it was over $500 for just the motor. You can buy them all day long on eBay, Zoro, and Graingers, for between $100 - $150.
jyoutz
Jan 14, 2019
3,624
2,718
Edgewood, New Mexico
I made a tie down for the front of my Mx by welding a 12,000 pound d ring to a square of 1/2” plate, then drilled a 1/2 hole in the plate above the d-ring. There’s a 1/2 inch hole in the frame on the lower front that I bolted the plate to and also made another 1/2” backer plate for the other side of the frame. That works for the front tie downs. For the back I was originally going to tie to a clevis in the drawbar, but realized that two anchor points are recommended, so I bought two 3’ axle straps to wrap around the rear axle for tie downs.
Daferris
LX2610
Nov 23, 2021
496
423
Mid-Michigan
I welded a couple of weld on hooks to small pieces of 1/4" plate that I drilled to match the 3 holes on each side in front. Then welded the head of the bolts to the plate. (10.9 grade flange bolts and nuts) in back I bolted D ring tie downs to the ROPS where the backhoe subframe would be with some 12.9 grade socket head cap screws I did have to spot face the D ring strap so the head of the bolts fit. Works well and I think it was about $50-60 for all the parts and hardware....
5,375
Nice clean install. I couldn't find any for my L2501 so I had to go a different route. 20230119_124434[1].jpg
hodge
Nov 19, 2010
2,960
531
Love, VA
There are tons of points that chains or straps can be run around or through, so I've never found a compelling need for dedicated tie down hooks or loops.
Daferris
LX2610
Nov 23, 2021
496
423
Mid-Michigan
Yes but having a dedicated tie down point is handy for ease of connecting the chains. As well as in the case of the front hooks a chain point for pulling a stuck tractor or other items out for example. Also some folks just want to hold down how many scratches/chipped paint on the frame.....
7,004
about $9 from harbor freight. no drilling, they fit perfectly. I put them on both sides and it works well for chaining to trailer.
RichardAaronlx2610
Aug 3, 2021
454
522
New Jersey
Yeah 150 is a bit steep. These were under 50 shipped, the shipping was refunded to the actual cost after my purchase, so I was pretty fired up about that. Hardware from tractor supply was an extra $6
RichardAaronlx2610
Aug 3, 2021
454
522
New Jersey
5,375
This👆
Plus I just like making things.
I can't begin to count how much money I have "wasted" by making things for myself.
I usually 'justify it' to the finance committee by saying "well those _________'s are gonna cost $500, so for that kind of money I could invest in a plasma cutter and make them for myself and then have a plasma cutter at the end"
Reactions: 6 users
Warrior67
10
Richard,
Would you mind sharing the information on where you bought the tiedown points?
I just purchased a LX2610 and need to add something so I can tie it down. I really like the looks of what you did.
RichardAaronlx2610
Aug 3, 2021
454
522
New Jersey
Richard,
it’s the rear brackets that i ordered that fit the front of the lx2610
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
129
119
Lopez Island, WA
This👆
"A project is considered successful if the cost of tools justified exceeds the cost of materials."
- Bart
