ken erickson
Maybe someone with DC barrel connector experience can clear things up for me.
I am wanting to order a adapter for a backup power source (12v 3amp output) that has a male barrel connector that measures 5.5 mm outside with a inside dia of 2.3 mm.
Which female adapter would I need to fit the male connector. It seems that the inside diameter of 2.3mm does match up with the adapters I am finding online. Either 2.1 or 2.5 mm is offered for the ID. Note: I do not know what the pin diameter would be.
I am including a picture of the male end on the power source and the dimensions of the OD and ID.
Not that it should matter but the device I am powering also has a input rating of 12v 3amp but has a socket/female that uses a male 6.3mm x 3mm end.
As a side note I miss the days of being able to run into my small town to the local Radio Shack and leave with parts I know will fit.
