Old_Paint
Dec 5, 2020
2,040
2,309
AL
Some time back I made a stump puller with a 4x4 post and some PT 2x4s that makes the chain pull up on the stump rather than sideways, better overcoming the theory that tree roots are designed to hold the tree from tipping over more so than just holding them down. After all, gravity works, right? I’d used some pretty pathetic c-channel with notches in the ends to keep the chain centered on top of the upside down Tee, which did pretty well until I got frisky with it and tried to pull up a 6-inch elm stump. Today, I replaced the cheap c-channel pieces with a crown I made with 3/8 x2 steel bar stock that has a good tight fit over the 4x4 and put the lag screws on the sides rather than front and back, and cut a notch 1.5 inches deep in the end of the 4x4 to allow the chain to go down into grab notches I put in the front and rear of the crown. Ran out of daylight and didn’t get try it out today, but it’s a lot beefier than the original design.
Next project is to build a carry-all box that will clip on the back of my BB1248 that I can carry my axe and saw so I don’t have a dangerous double bit axe waiting to cut me and will have plenty room for the saw oit and gas. I keep the BB on the back for ballast when using the stump bucket or grapple. A carry-all just wouldn’t be heavy enough.
radas
Mar 21, 2022
719
834
Pics of the stump puller!
Old_Paint
Dec 5, 2020
2,040
2,309
AL
I'll get 'em tomorrow, maybe. If I get back there pulling more stumps. Pretty soggy back there at the moment. Took nearly an hour to clean the hundreds of pounds of mud outta the tires before I put the LX in its bedroom. A low spot in my yard isn't low anymore.
DianneInVa
B3301 front loader; backhoe;
Jul 31, 2013
9
Fosston , MN
Northern Minnesota. Opened up livestock gates with bucket. Moved snow. Put on bale spear and Haybale out to the livestock. Used the RTV just drive around and have fun. It was a good day to be outside.
Reactions: 13 users
matt-m
2022 B2601
Mar 17, 2022
80
437
53
Columbus, IN
Fabing up a multipurpose carry all-ish type frame. Basket will go on and off with a couple bolts. A flat platform will be next. Couple hangers on the frame uprights pending getting something sketched out.
Reactions: 10 users
RMS
Sep 26, 2021
308
672
Buckfield Maine
When I built my carry-all I got a frame from TSC and put 8 60 lb cinder blocks on the floor and then put a piece of plywood over them. I still have over 3 feet of usable height in the box for other use.
11,757
Yesterday afternoon I used the M to drag an elk carcass up into the woods to feed the birds and beasts. I also moved a bunch of bark to the burn pile and got ready to cut up some downed trees that should burn well. The snow was over 2ft deep in places and no way that the MX would have made it the 1/2 mile or more I had to go. The M is a tank and had no trouble in some fairly deep snow and hilly terrain.
Flintknapper
L2350DT
May 3, 2022
2,024
2,578
Deep East Texas
Could you just put the carcass in the bucket? :unsure:
11,757
It was in the sled since early November. I could have moved it to the bucket, but since the sled was already in a bit of a state I didn't want to have two things to clean. In addition, the idea was to bring wood back in the sled and the bucket, but I ran out of daylight.
Old_Paint
Dec 5, 2020
2,040
2,309
AL
Yeah, that's a pretty decent frame for a carry-all, and certainly has a lot of flexibility. A little grinder work, and you've got a half-decent 3PH fork lift, too. Not very adjustable, but it's designed to go under a standard pallet. I've been eyeballing one of those at TSC for a long time, but it's a bit overkill for what I need for load rating, because I don't carry anything very heavy. One disadvantage is that it's on the opposite end of the tractor from the loader meaning it can't be loaded with the loader. If it were QH compatible, I might consider it just for the convenience of not having to build a frame. Making it SSQA and QH compatible would make it a LOT more useful. I mainly want something to put light tools (axe, chainsaw, pole saw, shovel, hoe, fuel/oil cans) that I can just drop near where I'm working with the tractor when I get there. Without making two trips. I could also leave it behind the BB when I park it in the shed if I'm doing the same work the next day, or just lift the BB enough to not scrape the floor, and drive off without it. Sometimes, I'm just flattening out the mess I make while digging up undergrowth and stumps, and don't need the hand tools. Doesn't need to be heavy, just adequate for hand tools, and quickly attachable or removable without leaving the seat. I've got some sketches done. Just need some more measurements to figure out how much box beam and hardware I'm gonna need.
6,684
If you make that, please post pics. That would be ideal for a lot of what I do. Just a light weight box that hooks to the boxblade so I’d still have the blade for counterweight and finish grading with a tool carrier that could be picked up at the shop and dropped at the worksite without a bunch of effort. Depending on the job, I might be running the bucket, forks, or grapple so making a carrier for the loader end of things isn’t ideal at all. The boxblade is more typically on the 3 point.
Flintknapper
L2350DT
May 3, 2022
2,024
2,578
Deep East Texas
(y)
johnjk
Apr 13, 2017
1,800
2,187
West Mansfield, OH
Dropped the wheel off at the local tire shop. Cleaned the rim and the bead and replaced the valve. Back on the B3200 holding air like a champ. Moved things over so I can get the B1700 mower deck off and to the welder while I pull the radiator and get that to a radiator shop.
trueg50
60
78
Vermont
Mixed day for me on my Kubota. Went to go pull logs out of the woods and everything was going great. Got the chains on the first log and when i went to get on the tractor i saw everyones worst nightmare, a flat tire! Queue a 1/3rd mile walk back to the house for rope and bike pump. Fortunately it was the front so I could use the loader to lift the tire and was able to pump it up (no rope trick needed to seal the bead). It got me home and I added air.
Interestingly the tire that was flat was at about 12psi, and the other front tire was the same pressure. I brought both to the recommended 22psi for the R14's and will be keeping an eye on them to see if they hold air. I think (and hope) it was just low on air and irregular terrain broke the seal.
Post lifting the front with the loader:
  • Sad
