L2052-1 Snowblower Fan Removal
Maple42
L3710
Jan 1, 2023
Wisconsin
I am attempting to remove the fan from a l2052-1 snowblower...does anyone have detailed guidance on what type of puller or device to use to release the fan adapter shear plate from the shaft? I see some threads in the shaft but before I damage anything, looking for advice.
Thanks
Maple42
L3710
Jan 1, 2023
Wisconsin
Possibly this will help you..
Thanks...I have all the info as shown on messicks (great company) the issue is the details on the type ofpuller or bolt thread details to get the fan shear sleeve off the keyed shaft...I believe it’s similar to taking off a snowmobile clutch but I am in need of the technical specs before I just mash in a wrong thread puller.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
870
canada
Can you go by the retainer bolt size and thread pitch.
Maple42
L3710
Jan 1, 2023
Wisconsin
The bolt that holds the shear plate on is a 3/8ncx2, but then it appears that another thread size is deeper in the shaft, maybe? Unless I’m thinking all wrong and once the retailer bolt is out I’ll have to somehow get that shear plate off the shaft (I’m guessing it’s never been removed since install at factory).
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
870
canada
One way would to remove the bolt and washer, then reinstall the bolt. Then push on the head of the bolt, with a puller. Once you get it moving, you may not need the bolt and puller.
Maple42
L3710
Jan 1, 2023
Wisconsin
My gut says I need a longer bolt that when I screw it in, it bottoms out on the shaft thus pushing the shear plate off the shaft... putting a puller on the bolt screwed in on the same shear plate doesn’t seem like that would do anything because it’s not pushing against the shaft.
#40Fan
564
395
The fingers of the puller would grip the fan. The center bolt of puller will push against the shaft (or bolt replaced in shaft).
Edit: Found this thread. Sounds like it just pulled off without a puller.
Maple42
L3710
Jan 1, 2023
Wisconsin
Thanks for finding that...I’ll find a moment between snowstorms to tackle this.
