5,707
Water service repair today. Tractor got the call for this one...probably couldn't have dug it without the street pads (for those of you on the other "street pad" thread). The frost under the concrete was causing me to slide towards the hole. had to dig it sideways
Pulled the old line out with the new copper line attached with the B2650.
new copper
wrapped up. ready to head home...
Reactions: 7 users
je1279
Dec 6, 2020
828
585
Upstate NY
I have what is likely to be perceived as a MUCH more serious problem !'
I removed my ROPS !
To each their own. However, I truly hope that you never encounter a situation where you regret that decision.
JimDeL
Aug 31, 2022
374
422
Austintown, Ohio
I removed my ROPS !
I've also (reluctantly) removed mine. My property is dead flat, with over 40 low hanging trees to mow around, making the ROPS very inconvenient. I'd really have preferred to keep it on, but...
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
Just got done snowblowing the driveway. *THIS* time it was rather nice. -2*C, 10km/h winds and 5" of powdery fluffy stuff. Pure ice underneath so walked very carefully and rears of the BX are chained up.
Although you can't see it, ironically the patch on my coat says "iceman", LOL
Reactions: 8 users
trueg50
60
78
Vermont
Blowdown cleanup has been the order of the day. Did road clearing for a cell tower on the property. We had a few hemlocks and other trees coming down on the road, and a major blow down with a mix of Tamarac and red maple. , there were two 16" diameter maples and one to two 12" or so maples.
The kubota saved me with the tamarac (second picture, tree in the middle) I couldn't cut the supporting branches without risking the tree rolling on me. I was able to grab a branch with the grapple and pull, this helped roll the tree and drop it to the ground. Like the tamarack, at least one maple also wanted to slide to the right (down towards the stump), and again a nudge of the grapple saved me from risky work. It also let me just grab logs and move them aside so I wouldn't have to buck them all and move by hand. I measured a few logs by doing partial cuts at 16" just to get a feel for the lengths I wanted. This was a huge time and energy saver! This part of the road was past a steep hill that was slick and I only had a short window before it became impassible. I was dead tired towards the end, so any grapple work was a godsend.
The work took 5 hours to get the blow down and 3 other trees cleared. I finished just at dusk. This summer I'll be back for the rest of the wood and a few other large maples the storm blew over.
Nothing more fun than hitting the grapple close button and crunching the tamarak that tried to kill you.
Reactions: 9 users
5,135
Tractor trailer took out at least one power pole and a transformer up the road a bit. First real use of generator last week; second use this week. We have a couple of neighbor friends that think we’re odd running a generator off the back of a tractor. I think they’re odd sitting in the dark hoping the power company sorts it out quickly.
Reactions: 9 users
Flintknapper
L2350DT
May 3, 2022
1,971
2,497
Deep East Texas
That's some serious light there. Is that accomplished with headlights alone or do you have Aux lights?
Flintknapper
L2350DT
May 3, 2022
1,971
2,497
Deep East Texas
View attachment 93064 View attachment 93065
Man I envy you guys with grapples. I keep struggling to warrant the purchase of one for my compact tractor (L2350DT). The lift capacity (at full height) is only about 900 lbs. So I couldn't really pick up and move any large heavy logs....but it might be more useful than I imagine.
If I had a larger tractor.....I would have one for sure. Certainly looks like a labor saver.
5,153
My step finally arrived from Canada, so I put it on today. Strange thing is that it didn't come with any instructions, but it wasn't difficult to install. Pictures tomorrow.
forky
Feb 23, 2021
304
331
Wisconsin
Tractor trailer took out at least one power pole and a transformer up the road a bit. First real use of generator last week; second use this week. We have a couple of neighbor friends that think we’re odd running a generator off the back of a tractor. I think they’re odd sitting in the dark hoping the power company sorts it out quickly. View attachment 93090
How many hours can you run on a tank of diesel, and what rpm work's well?
Also, if a regen was needed, would that be a problem?
5,135
Run time depends on load. Based on the limited use we’ve had so far, it’s been a bit the less than 1 gallon per hour. 13.5 gallon fuel tank but no way I’m running it out of fuel so I’d say 10 hours realistically. First time out, ran a total of about 8 hours on about 6 gallons. I know that because it was full when it started, put a 6 gallon can in it to top off this time and it took all 6 gallons but barely. Ran around picking up stuff with the grapple for about 20 minutes between generator runs but I don’t suspect that burned much fuel.
This time 3.5 hours on what the gauge would translate to about 3 to 4 gallons but the gauge isn’t exactly a precision instrument so hard to tell. If it was summer and we were running A/C instead of the oil furnace, it might take a wee bit more fuel.
RPM is about the 540 PTO mark on the tach. I set RPM by the voltage and frequency meters on the generator rather than the engine tach.
So far as I know, it hasn’t demanded a regen while on the generator. I’ve had it run a regen while running the chipper at 540 and because I wasn’t in the operator seat I didn’t know it was doing it until I went to throttle it down to stop the chipper and saw the regen light on solid. About one minute later it was done without my involvement. At the RPM it’s running for the generator to make 60hz I would expect it to regen just fine without me, same as it did with the chipper.
Chanceywd
Mar 26, 2021
718
665
central ny
I can relate to that! When we had an 8 hr outage last year, neighbor said they were going to get a generator. Well a year has gone by and they still haven't. It isn't like they can't afford it. they have bragged about their retirement income. I still went up and helped them when a pine tree fell on their house last year too. Me, my chainsaw and kabotu did the the hard work but Ray who is 80 was there waiting for the next limb to drag away.
Bill
Old_Paint
Dec 5, 2020
1,887
2,024
AL
Not much. Just ran it for a while after topping off the fuel tank.
I had some summer diesel in the tractor, and have since filled cans with winter variety. All has been treated with winter additive and biocide, but conscious of diluting that summer diesel as much as possible.
That looks identical to the HaulMaster (Harbor freight) QH that I have. Have a look at these photos if you want to make it work even better. Your turnbuckle style stabilizers might even make that QH even less forgiving when you're trying to back into an attachment because they don't have as much slack as the telescoping type stabilizers. The sharp edges on those hooks catch on things pretty badly and just push the implement around rather than centering the QH in the lift pockets on the implement. About the only thing it does do is keep the lift arms spread the right distance. Not much point in having a QH that you still have to get on/off the tractor and use pry bars, etc.
You'll also find those are Cat 3 hooks. Tractor Supply has some great incremental bushings that will let you go from Cat 1 to 2, then 2-3, which helps tremendously with anything that has to have a tight and rigid connection to the 3PH. You can get them on Amazon as well. I get another set every time I get a new piece of 3PH equipment. Coat 'em with grease/graphite, and they make excellent rollers to let the pins slide down in the hook very nicely.
The mod in those photos made a HUGE difference. I can pop my BB on in a blink now without leaving the seat, and there's no more struggling to level the blade because of slack in the connection. The chipper takes a little longer because I have to connect the PTO shaft first, but otherwise, I back up against it and lift. The only reason I can come up with those hooks being so square on the edges is a cost reduction in production after cutting those parts from steel plate with a plasma cutter. The hooks are a LOT larger and stronger than anything you'll ever pull or lift with it, especiallly on that little BX. If this was being used on a Cat 3 tractor, well MAYBE you'd break it, but it's pretty stout.
I used cut-off wheels on an angle grinder to remove the bulk of the material from the corners, then a flapper wheel to shape and smooth them. I have ZERO concerns about breaking it with my LX or any of my implements.
IMO, it could have been about 2 inches shorter vertically which would have moved the top hook up a couple holes and made it a little more adjustable. Having to put the top hook in the very bottom holes for Cat 1 implements is a bit annoying. But, it does the trick, and fits anything I have with a QH Compatible sticker on it. An ongoing project I have is modifying my 3PH Receiver Hitch drawbar so that I can just drop it on the QH and boogie. The next thing I'll mod is my sub-soiler so it too will fit on the QH. I need to build a rack for that as well, especially if I get it QH compatible. I'm in no particular hurry though. It's shed time that keeps me outta the missus' hairdo.
BXHoosier
BX24
Jan 21, 2018
497
591
Indiana
Changed the terrible sloped factory seat out for the Countyline Kubota seat from TSC. Now, I don’t feel like I’m going to slide out of the seat and my back actually touches the back of the seat. The factory seat had about a 45 deg slope on the back. It’s not a direct bolt on seat. The front holes lined up and I had to drill 2 new holes in the mount to line up with holes in the seat. I also had to add some 3/16” thick spacers under the seat for the edge trim to clear the bolts on the slider rails.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
I have a lightbar on the ROPS facing forwards and 2 smaller lamps facing backwards.
I also have a multicolour beacon lamp in the middle of the ROPS that flashes up to 10 different patterns
in orange and white, so depending on what "moment in time" I take a picture, some of the light may be captured from the beacon as well.
Here's daylight pix of the lights. I don't need to use headlights really, as it just mostly lights up the back of the blower or FEL. I do also use the rear hazards though.
Flintknapper
L2350DT
May 3, 2022
1,971
2,497
Deep East Texas
View attachment 93172 View attachment 93173
Very nice. It certainly puts out more than adequate light.
I had ordered a light bar for mine last week (haven't received yet) and hope that it illuminates even half as well as yours. The brightness in your photo really caught my attention. Thanks.
Flint.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
Flint.
Thanks very much for your kind words Flint. I don't mind snowblowing, but I don't especially like doing it in the dark, from the safety standpoint. (well over half of my snow cleanup here is before sunrise or after sunset, thus investing a tiny bit of $$ in lighting was a no-brainer.
Even on my walk-behinds in the past I'd rig up alternative lighting, just so I knew I wouldn't be running into or chewing up stuff - LOL
When I put the lights on, it's nearly like daytime for 30-40' (or more) in most directions. I could use a tiny bit off to the sides, but as the tractor really only goes forwards and backwards, I think I'll be good. !
5,707
post deleted.
5,178
I don't remember if I received any install information with my step either.
Paul and Kathy sure do make nice mods though.
You will love the safety and stability of your new step.
Congratulations on a very wise choice!
5,178
double Orange dig today for waste line repair...
It's going to take some significant clean up effort in the spring...
There are 11 children in this household, so, there was a real push to get them re-connected. Not finish grading. It was quite deep so there will be lots to settle. Not how I typically like to leave them.
Kinda deep!
Spoil pile kinda close.
Trench box not required by local codes?
