motionclone
My 2020 Dually 7.3 F350 worktruck is an extracab. I took out the back seats to make room for tools and in the process, removed the rear seatbelts. Since then my airbag light has been on, presumably because seat belts arent hooked up. So I took to the dealership to disable those seatbelts due to there being no seats as well as some warranty work and they say they cant disable those because its a safety issue, liability blah blah blah.
So i say, actually, having my airbag light on all the time is a safety issue because if i there is a fault in my front airbag system (where the seats actually are) i wont know because the light is always on. They say yeah good point but sorry no can do. Oh and we cant put a safety inspection sticker on because your airbag light is on...lol
So is there a fix or workaround for tricking the system? If i put the seatbelts back it will be in the way of my tool area.
Also is there a way to disable the key in ignition, door open chime? If youre in construction you will understand.
Should i or could i use Forscan to fix/disable these things? Anyone else deal with this?
