Breaking causes Tractor to stop
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
In a car the operator controls the throttle, on a tractor the operator sets the governed engine speed. When using the tractor brakes the governor will go full throttle if necessary to maintain its set speed, thus the safety switch.
This is not true for the OP 's tractor. It is an older tractor.
It uses the throttle to set the rpm for either land speed or PTO rpm. Downhill the tractor will try to gain speed and the rpms will rise. A steep uphill will cause the engine to lose some rpms.
In either case you must adjust the hand throttle accordingly.
5,152
Sure hope that this tractor is equipped with a roll bar and seat belt. If it were mine, it wouldn't be mine for very long. I would take it to the Kubota dealer and trade it for an HST tractor with some safety features that will help to keep me from killing myself by making an irreversible mistake.
3,210
Not having a gear tractor, I don't know. BUT I THINK I read here at OTT that at least some gear tractors actually have a throttle pedal? I assumed this might be the case, but not sure at all. Never been around a gear tractor...Probably would not make sense if doing plowing and so on.
Something I have no need to know, but curiosity is a weakness of mine I guess.
By the way, I now have the impression there is no safety switch on the brake pedal of the OP's model tractor. Did I get this wrong too?
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
This is the bigger cousin of my tractor.
There is a foot throttle and a hand throttle. They can be used together. I use the hand throttle to set the rpms high enough to keep the battery light off and then plow using the foot throttle.
It is no more dangerous than any other tool when used correctly.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Is it being sold by the Nigerian Prince or your Russian girl friend?
Let's play nice and not scare the newbie away.
As to 6 grand. Depends on the condition, actual hours, and how well it has been maintained. It is on the high side but not crazy.
liam.hanninen
Kubota B7200 manual
Dec 20, 2022
32
14
North Carolina
Thanks. It says 350 hours but I don't know if/how many times it's turned since it only has three digits plus the white one for fractions of an hour. The condition doesn't seem great but I don't know enough yet to know if it's just appearance and small fixes or costly neglect.
5,170
The title of this post?
"Breaking causes Tractor to stop"
No surprise there.
When you "break " 😥any piece of powered mechanical equipment it very likely will stop.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
It was an honest typo. Cut the OP a brake break. :ROFLMAO:
