So still learning about diesels and their finer points of operation. Today took the tractor out (G2160) because still lots of leaves to chop up. Cold day today (about 30 deg) high temp, though so it was a little bit of a beast to fire up. IDK if it was coincidence or not but my starting method is set the throttle to what would be a fast "idle". App 1500 or so RPM. Do a cycle on the glow plugs (today 2 cycles), a crank away. Lots of cranking about 20 seconds worth and I stopped to give the starter and battery a rest. Then another go around with the starter. After a bit I started noticing some telltale smoke begin from the exhaust. So on a whim I decided to give it just a bit more throttle while cranking and if fired up. I know diesels are not the easiest things to get going in cold weather. So it begs the question: Should I have given it more throttle right from the "get go" and maybe it would have fired on the first cycle? IOW would there have been benefit in giving it just a bit more initial throttle? Gas engines are fairly simple beasts. But, the finer points of the diesel still escape me a little
