The_Wingnut
Grand L4060, ZD21, ZD28, ZD331, RTV X1100C, Branson 3820, JD 1020, JD 50
Dec 8, 2021
91
Tyner, NC
Did another round of leaves and grass pickup for us and the neighbors. Sure is nice having a small dump trailer! Then the Mrs. put a new SMV sign she made on the ballast box as I had painted the box a month ago and peeled the old one off.
Sure wish this weather here in MI would continue.
Is your dump hydraulic off of the tractor remotes or battery electric over hydraulic? The reason I'm asking; I have a dump too but it's battery electric over hydraulic and I have to stop and recharge after 2 maybe 3 dumps.
The_Wingnut
Dec 8, 2021
91
Tyner, NC
Mowed the area between our driveway and my naked neighbor's, loaded with wing stem. He came out later and asked me if I'd mow some of his up among some trees as he could not get his 4 series JD in there. I did it. He offered me a beer, but I had to turn that down because I have severe celiac disease, and been is gluten.
Why is your neighbor naked?
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,670
4,315
PEI Canada
Ordered a replacement head light for the LX3310 and gave my chainbox a from Boltonhooks.com a test fit on the QH. I'll get it mounted this weekend.
Old_Paint
Dec 5, 2020
1,984
2,211
AL
Transplanted a couple azalea bushes with the stump bucket today. Already hauled several loads of leaves to the back in the past couple months. I'll be hauling leaves until February. Sure could use a nice looking dump trailer. Hard to justify the cost though. Don't have enough property, and ain't interested in hauling stuff for other folks.
BX23S
2022 Kubota L3901 FEL, BH, GRAPPLE, PALLET FORK, SNOW PLOW and Hard Canopy
Sep 1, 2018
70
41
ID
Thanks Bud!
The dimensions are 12 ft. x 13 ft. H 8'-6" slopping back to the rear at 6'-6"
I used milled timber 6"x7" and some 8"x8" timber. Couldn't
have done it without Orange!
The bottle opener is on the inside. :cool:🍻
3,480
Sounds like your battery is on the way out.
My 3yr old Loadtrail has done 11 loads in one day without needing recharging.
5,166
Or the battery isn't properly sized for the demand that is put on it. Get the highest CCA battery that you can find, and if you can find a AGM battery that is better than any lead acid battery.
The_Wingnut
Dec 8, 2021
91
Tyner, NC
Hmmm, I'll have to look and see when I last replaced the battery. Thanks for the advice on a replacement type.
Trapper Bob
L4701, Wicked grapple, 7’ box blade, 6’ Wicked bucket, SVL 65-2 w/4 in 1 bucket
Jan 17, 2022
446
819
Andover, KS
I use a deep cycle marine AGM battery in my dump trailer.
11,679
Lots of tractor work this past weekend and this week clearing up the "barn" that collapsed and making a burn pile. Then there's the firewood debacle. I'll be cutting, loading, splitting and stacking all week no doubt! The small dump trailer is brilliant behind the M, and in case anyone's wondering, I have a chain connected between the draw bar and the King Cutter receiver so that the 3-point can't be lifted by the trailer. I've said it before but the M is a phenomenal tractor and just a joy to own and use. I should have bought an M six years ago but I didn't have a clue about my needs back then.
In an unprecedented move for me I have the MX ready for winter with the front snow blade and rear blower hooked up, adjusted and serviced. Typically I'll be messing with this stuff in the middle of a snow storm and with freezing hands! The guards on each side of the blower were installed incorrectly (see photo) so I fixed that issue. I was going to run the snow blade on the M this year but maybe not. Having two tractors really is the way to go for me. It's so convenient to have them set up for different tasks.
Reactions: 15 users
11,679
I have two PJ dump trailers, a 16ft and 10ft, both electric over hydraulic and both have the standard lead acid batteries that they came with, and surprisingly I haven't had a problem with either. The trailers have outlets on the outside of the tool/storage boxes with internal trickle chargers and charge indicators but I don't often bother to run an extension cord to them. I do remove the batteries in the winter and keep them on a trickle charger which probably helps.
Like @Trapper Bob I'm a fan of the deep cycle gel acid type batteries having two Optimas in the F250 and one in the Jeep TJ. I haven't needed to buy any for the trailers yet, but when it's time to upgrade I'll most likely get Optima batteries for both.
The_Wingnut
Dec 8, 2021
91
Tyner, NC
Beautiful land! Tractors nice too.
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
Back hoe off. Wood chipper on to clean out a brush pile. After this I will put the MMM on and the cyclone rake on and clean up the leaves. Heck after that I might even wash it before the next project. IMG_4975.JPG IMG_4976.JPG
Reactions: 7 users
S-G-R
Jun 17, 2020
1,670
4,315
PEI Canada
Out with the old
and in with the new. About a 15 minute job to get them swapped.
S-G-R
Jun 17, 2020
1,670
4,315
PEI Canada
Next order of business was to install one of @Kennyd4110 chain boxes with lid and a pair of Quickfist buckles to the QH15. About another 15 minute job. Easy to follow directions and top notch product.
16' of 3/8 chain
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Replaced HST filter. When it hits 800hrs, I will be back on the maintenance interval.
Finished up my food plot.
Reactions: 8 users
