L2501 Turbo: A Journey Defined - The tractor, The comparison, The modification, The results...
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
I fully understand. But, I’m just trying to figure out why the D1703 vents the CCV/PCV gasses back through the intake manifold and not to atmosphere, or the ground and why I should route these gasses differently with the Turbo.
You could have a runaway diesel scenario N/A or Turbocharged.
I have zero reservations venting these gasses to the ground, or atmosphere (it’s easier) but it’s imperative that I understand the rationale between the OEM operation and the suggested modification.
Mike
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
It's more likely to runaway with the crank case vent going to the intake.
The only reason I can see for running the pcv back to the intake is environmental, you drip a few less drops of oil on the ground and it might help the engine get slightly, probably not measurable better fuel economy.
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
It would make sense that Kubota is running the gasses back through the intake for Tier 4 emissions requirements.
Mike
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
All that does is virtue signal, drive up tractor costs.
This will only accomplish making 40 year old tractors last another 40 years.
Dieseldonato
Mar 15, 2022
728
439
Pa
Perhaps a silly question... In your description of the installation design and the process of installation I'm not sure I read about how you sourced oil to pressure lube the turbo. Did I miss this?
Also... just a casual observation from a different industry. EGT readings are highly subjective. They are subject to large variations based on probe location. In one test we saw a 50 degree difference in EGT reading when we moved the probe from one side of the exhaust pipe to the other - all other variables were the same. Distances between the exhaust valve and probe, angle at which the exhaust impinges on the probe... all these little things produce measurable differences in sensed EGT. I only mention this because you have discussed EGT in terms of absolute values when, in fact, those absolute values can only be meaningful when comparing identical EGT probe locations.
Now you've got me thinking that my little B2410 might need some "help" making more power to deal with heavy snow-blowing loads. Ohhh this is the kind of thinking that gets me in trouble!!!!
In a perfect world you should be reading temp right from the exhaust port on the engine. Realistically preturbo in the exhaust manifold, preferably in one of the hotter running cylinders.
Dieseldonato
Mar 15, 2022
728
439
Pa
Mike,
Please don't do any kind of crankcase to intake feed on a diesel. Yes, it's nice for the environment to burn up your crankcase vapors. No, it's not safe on a mechanical diesel.
If your engine starts to malfunction - e.g. busted or bad leaking rings and gets blowby or fails otherwise (diesel in oil and surely other issues) having a crankcase feed to intake will and has caused runaway dieseling which will grenade your motor and tractor. The pcv thing feeds to a dump tube to atmosphere for a reason.
Thanks!
I've seen engines run away form a lot of things, the crank case vent has never been one of them. Turbo, broken rings, mis aligned Piston cooling nozzles, fuel racks sticking. Never once seen or heard of the vent causing this. It's unrealistic at best and a lot of diesels engines have closed loop crank case vent systems.
drewzee87t
L45 TLB, B2910 Turbo
May 20, 2016
176
misery
So there ya go. :) This guy has your back and he has studied this.
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
I'm reading the EGT temperature pre-turbo in the Turbo adapter, which, in this case, appeared to be the best compromise.
Mike
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
Tractor is continuing to run strong with more than enough power to accomplish all tasks. I haven't experienced any hiccups or issues with the Turbo setup installed.
I'll be installing a couple new hose clamps on the Turbo inlet pipe to match the other clamps and I'm considering installing some steel-braided lines for the Turbo oil feed and drain.
Mike
Snowman7
May 20, 2020
395
288
Boyne Falls, MI.
So interesting, and way over my head to fully appreciate. Very nice job and excellent write up.
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
Thank you!
Much appreciated.
Before;
After (new T-clamps);
Swapping the hose clamps was solely done for aesthetics. Obviously, this small modification wasn’t necessary. The old hose clamps work just as well as the new T-clamps. I just like things to match and look ‘clean’.
Mike
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
Some of mine don't even have hose clamps. I ordered one of the wrong size elbows. So I just spit on it and jammed it on there. It was a 2.25 inch elbow in a 2.5 inch pipe.
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
Totally! They're not entirely necessary depending on the circumstances.
However, I'm pretty particular...as you can see, lol
Mike
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
Finally! I have found the elusive PTO Dynamometer and a shop eager to test my L2501 Turbo!!!
I'm hoping to have my tractor scheduled for a Dyno session in the coming weeks. I'll keep you posted!
Mike
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
I was able to get it on the dyno sooner than expected;
HUGE power improvement!!!
We’re very happy with the results and safe EGT’s. More info to follow!
Mike
4,634
Thank you!
Much appreciated.
Before; View attachment 93880
Mike
You sir are a true craftsman and pioneer. Great write up!
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
Thank you!
Wait until you see the results. You'll be very happy you bought an L2501! :D
Mike
Rdrcr
Vendor Member
May 7, 2021
747
915
WA
I'm sure if someone is interested, I can put something together for them. And, I’m still planning on changing/upgrading the Turbo oil feed/return setup. So, I can definitely put a parts list together but, right now it’s still evolving.
Mike
