Ton
BX2380
Aug 26, 2022
58
116
MD
New Tractor disposes of the old tractor. 😎
  • Sad
Reactions: 7 users
6,897
Driveway extension project is getting under way with some "helper" machines to do the heavy lifting. I haven't run a skiddie in so long it's like starting over. With the pilot controls, I feel like I'm in the mini-ex but the sticks don't do the same thing! Hopefully I can get the hang of it quickly.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,539
central ct
A couple of days ago used the fel to load my tiller on the gentleman's pickup. Craigslist :). He drove in from RI and I think he will get a lot of fine use from it on his farm.
Today was the grapple's turn. I moved a large rock from the woods to the top of our driveway. Its more of a deterrent than a landscape feature. Too many trucks clip the curb and my landscape edging. Just tired of repairing the edging.
  • Dislike
6,897
A little more progress made today. This shot was from earlier in the day. The cut is quite a bit deeper now. Should have the cut done tomorrow and road fabric installed. Monday, #3's should be here. I want to get this finished before the next rain later in the week.
Neighbor loading millings from his "stash". Fortunately, he's a couple hundred yards away and has access to something a bit larger than the Kubota. ;)
Dakota guarding the millings pile.
RDinNHandAZ
Kubota BX1870, FEL, BX5450 Snowblower, back blade, customized snow cab
Jun 26, 2022
103
133
Lakes Region NH and Sonoran Desert AZ
This morning at 6:30am I looked out onto a white lawn! Frost not snow thankfully. I am ready for snow I guess. Yesterday I stored the FEL inside the back of the barn, got the snowblower on and lubed it up. As the whole BX1870 was new to me a couple of months ago I had to do some trial and error to get the blower attached. I didn’t know which hydraulic ports to attach the blower’s lift to and the adapter and blower’s short PTO shaft was separated in the middle so I tried to put the blower on and line up the square shafts at the same time..... no go. When I put them together before installing the blower I had better luck. The rest was easy. Now I need to adjust the skid shoes to get the scraper off the ground by a bit, mount a tool holder for a couple of wrenches and toss in the spare shear bolts I bought. The manual rotate handle was not smooth at all so I applied zinc based anti seize compound to the gears. I hope that works in snow.
ACDII
Oct 21, 2021
690
432
Illinois
What is it said about a picture says more than words?
5,162
I used to have the same problem with the snowblower PTO shafts and the reason it is difficult to align is that they appear to be square, but in reality, they are rectangular. I used a file to cut a notch into both mating halves, so when I need to align them, I just matched up the two notches and it went together smoothly. Don't forget to lubricate and adjust the chain on the snowblower. I had been using chain bar oil for many years, and recently a neighbor told me that he uses "fluid film" on his snowblower chain as well as his motorcycle chain and that it works well. He is the only person to mention this, so I have no idea of how well it actually works over time.
6,897
Today's progress report.
My new spoils pile:
Hoping that triaxle of #3's show up in the morning...
6,457
Ordered a Woodland Mills WG24 stump grinder Tuesday hoping to get it by mid- November. C6ADAE36-1AC9-4E8D-BFFD-591AAD365F2A.jpeg It arrived Friday. Had time to put it in the shop but didn’t anticipate being able to put it together and try it out for a couple of weeks. CDD6F436-E5B4-4B53-BC6C-4AB47D909614.jpeg
Had just enough time Sunday afternoon to get it set up and try it out on one stump before it got dark. Took about 10 minutes to take out a stump in the middle of the road to the shed. If I knew what I was doing wouldn’t have taken that long but for being first time I used it, it went well, I think. I was very pleased. C6C71E7D-E11D-4E98-AE8E-E3F597CD84C9.jpeg
Now I just need to put some casters on the shipping pallet to make a storage dolly for it. 🙂
5,162
I added some non-slip material to the steel door bottom edges of my BX23S with the Curtis Deluxe Cab. Almost fell last winter when getting out of the cab with snow on my boots. MVC-023L.JPG
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,694
4,437
PEI Canada
Used the forks to load the FDR2584 onto the trailer, taking it out to my parents barn for the winter. Traded my box blade in for a GS1560 Landplane. Gave it a test run on the driveway. Found it to be a bit aggressive so I need to readjust the blades.
6,897
Got the #3's and millings roughed in yesterday after work. Hope to dress it up with final grade after work today and call this project DONE.
Reactions: 6 users
Biker1mike
Jan 11, 2022
1,174
1,275
Gallatin, NY USA
Did my last 300 hour maintenance , I think. Grease, gear oil, and hydraulic fluid. Hopefully we will be in a low to no maintenance abode before the tractor sees 300 more hours on the clock.
Stone driveway, so laid down plywood and worked on the ground. Between getting older, way too much stomach fat and recovery from quad tear I am more than happy to not do this any time soon.
Still looks pretty good for 36 years of earning it's keep.
Reactions: 8 users
6,897
That's a wrap...finally.
I had the get the obligatory pic with the Oranges.
Reactions: 12 users
Trapper Bob
L4701, Wicked grapple, 7’ box blade, 6’ Wicked bucket, SVL 65-2 w/4 in 1 bucket
Jan 17, 2022
446
819
Andover, KS
Played fetch with the Kubota today.
Reactions: 10 users
Trapper Bob
Jan 17, 2022
446
819
Andover, KS
Yes, & there are plenty to choose from for corner posts. These are going to be turned into BTUs.
