WhitleyStu
B2601 LA435 FEL 60" MMM 60" Snow Blower FSP500 Spreader 5' Grahl Roller 40 spray
Sep 10, 2020
58
104
Indiana
Sprayed 60 gallons of bifenthrin to keep the spiders and other small critters from trying to come in during the cool fall weather...
Reactions: 8 users
DaveFromMi
L3901 RCR1260
Apr 14, 2021
655
656
Indiana
I have had no luck using chemicals other than Raid that is sprayed directly on them. I have found a couple of things that do work. 1. Peppermint (essential) oil diluted in a pump sprayer to the inside perimeter of the pole barn and basement. 2. Hedge apples cut in half placed in the 4 corners of the barn and basement. Farmers around here have used hedge apples for generations.
fj40dave
Sep 24, 2009
425
257
Yelm, WA
My neighbor's husband died unexpectedly a few weeks ago. She asked me to fix her non-functioning gate to feel safer. The post is about 5-6 inches from plumb. Anyone with tips tricks on how to get it straight please go to "projects" and help me out. View attachment 88080
I did 25 horse fencing posts recently....3' deep hole, packing in each layer by hand on the setting.....a lot of rk, but they are SOLID!
10,583
Nothing too exciting. I had a box full of plow parts show up so unloaded it from the back of an MTL truck using the MX and pallet forks. I ran the flail along the side of ~400 yards of driveway as I headed back up the hill since I was going that way any way.
ken erickson
Nov 21, 2010
1,345
2,412
Waupaca Wisconsin
I started the day greasing the loader and tightening one of the angled zerk's that had loosened up. Continued my wildlife pond dig, approaching 50% done moving soil. I started building up the dam and at the point that I need to re-establish elevations. I am not sure how much more excavating I will do this season yet. I have a lot of grapple work now that a lot of my Scot pines that died off are starting to get brittle and falling over.
Reactions: 8 users
Flintknapper
L2350DT
May 3, 2022
2,021
2,568
Deep East Texas
No pics from yesterday cutting a maple that was in the way of the driveway extension. I made a real bonehead move in felling the tree with winds gusting. I had purposely parked the tractor behind some trees in the opposite direction of where I wanted the tree to land. Ok, all good there. However, after I cut the notch and made fairly deep back cut the tree was starting to go. At that second, a strong gust of wind blew the top of tree and it sat back entirely on the back cut! It was ready to break and I thought the tractor would be done for. :eek:
The wind gust stopped which opened the back cut and I pushed a wedge into it by hand. The momentum of the tree springing back when the wind died was enough to break the holding wood and the tree dropped right where I wanted it to go. Yeesh.
I got extremely lucky and learned a valuable lesson. Pick a better day with calm winds when monkeying around with trees.
Yep.
Wind gusts and trees being 'limb heavy' on one side are considerations that some folks overlook or just get caught off guard by. Glad it worked out for you. Scary moment I am sure.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
East day. Put the 3 pt drawbar with the trailer ball on and moved the camper from its ready to go spot on the driveway to its winter home out of the way so I can plow.
Just a pop-up.
Ton
BX2380
Aug 26, 2022
58
116
MD
Got my GWT version of a "heavy hitch" in today and procured some 70lb suitcase weights. Very odd color for the weights, though. I can only describe it as a sort of moldy-vomit type of color. Very off-putting. Looks like the dog doesn't think too much of it either. But the additional ballast is very much welcome. Now just need to fab up a front bracket for them as well.
Reactions: 12 users
utkdoc
15
17
usa
Same customer as the previous what did I do with my Kubota post...
This project was to create a parking area for the customer so he can park up to 4 vehicles or his motor home on a level surface.
When you use the plate compactor on that stone, how long does that usually hold up for? I know depends on how much you drive/turn on it but in general. Does it just give a smoother surface or do you think that helps prevent pothole / low area formation also? I've always wondered
3,617
2,210
Clearing a site for a (hope) shed/shop. Pulling and digging saplings and trees. It took all Katy had to dig/pull/haul this old sweetgum stump.
What I'm clearing is younger than what's behind her. But when those sweetgums sprout from an old stump with its established root system, they grow like the weed they are.
L35
Jun 13, 2010
672
773
CT
Looks like my boy..
7,188
Mowed and then greased the mower deck, plus the zerk for the treadle pedal in the floorboard.
Had it a while now, but if you have a Milwaukee M18 tool kit, I highly recommend their grease gun with the Lock-n-Lube coupler.
6,519
Banged out 3 more stumps after work tonight then built a ramp to storage container with some #3's and millings.
Stump 1:
done
stump 2:
done
stump 3 done. no before pic but was a very large ash.
Reactions: 9 users
Chanceywd
Mar 26, 2021
772
732
central ny
Yeah. Look like they could be brothers. Mine is a German Shorthair mix. Great dog. Was supposed to be a hunting dog, but he's way too much of a softy. just wants to play and cuddle all day. He's a good boy.
Love GSP's I have had a few, just a couple mixed breed rescues now. Always wanted to have a drahthaar with their bushy face hair!
Bill
leveraddict
Apr 1, 2019
905
594
NEPA
fj40dave
Sep 24, 2009
425
257
Yelm, WA
It does give a nice firm surface, but the turning or tire slipping when starting out will certainly cause the pothole opportunity(s).
There are basically three layers to the parking spot I built:
1st: 2-4 Rip Rap (Tailings) to give a firm base locking into the existing dirt/rock
2nd: Fill....which the owner arranged....not my standard, but it's his property, and he went with material I thought was from a abandoned wrecking yard! Horrible stuff. I usually use pit-run stuff, compactable, and usually nothing toxic for the ground.
3rd: Either 1.25 minus or 5/8 minus about 4-6 inches thick compacted.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,586
3,970
PEI Canada
Loaded the tractor onto the trailer for a trip to my uncle's to clean up his yard after hurricane Fiona. HLA 60" root rake/grapple and RTR1266 tiller for ballast.
Reactions: 6 users
