BX24 winter cab build
BXHoosier
BX24
Jan 21, 2018
509
626
Indiana
Thanks Henro
No wiper yet. I’m worried that a wiper will just end up scratching the acrylic windshield. I’m going to try using the Rain-X made for plastic.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Thanks Henro
I used that on my side x side in the rain, it works pretty good. I was able to splash water on the windshield when it got mud water on it and help wash it away. It's worth a shot!
BXHoosier
BX24
Jan 21, 2018
509
626
Indiana
Got the door glass installed with some silicone and screwed on strips of PVC molding to retain the windows. 93030518-411E-4BD4-8633-F2A88043DA57.jpeg
5,165
Looks good. I'll bet that you can't wait to try it out to see how well it works, and then you will hope to not need it again for a while. I remember when I got a cab on my tractor, how pleased I was to be in the warm surroundings. Now I dread winter since it still takes a lot of time and effort to clean up the snow to bare pavement.
BXHoosier
BX24
Jan 21, 2018
509
626
Indiana
Got the weatherstripping on the back and attached the back panel. The small lower window is in and the window gasket is in for the upper window. Today, I wired the front work lights and wired a couple of LED dome lights inside.
46A303C6-562D-4C1E-8DDF-136A9384A63C.jpeg 432B533B-50C4-4635-B967-37ADFD611AB4.jpeg
Reactions: 6 users
BXHoosier
BX24
Jan 21, 2018
509
626
Indiana
Installed the rear window today. All that’s left is to seal along the bottom of the doors and plumb the heater. I drove it a little yesterday with the doors and back panel on without the back window and it’s definitely louder inside the cab than as an open station. Time to invest in some Bluetooth hearing protection. Cheaper then sound deadening the cab and installing a radio.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
All you need now is a TV, stereo, hot plate and compostable loo and your wife may never see you again ;-)
(seriously, great job !)_
Ping
BX2370-1
Dec 25, 2018
357
368
Troy, Ohio
What?!?!?!?! No adult beverage cooler?
Otherwise, looking good. You should be ready before the nasty white stuff starts falling.
Regards,
BXHoosier
BX24
Jan 21, 2018
509
626
Indiana
Regards,
No cooler. Just the factory cup holder. Thanks Ping. I’ll actually be ready for the snow this year.
BXHoosier
BX24
Jan 21, 2018
509
626
Indiana
Finished sealing the doors with some simple stick-on door sweeps that I added screws to.
I made some rain gutters to keep water from running off of the top and onto the windows. I used 1/16”x1-1/2”x1-1/2” aluminum angle that I formed over a 1” diameter bar with a soft dead blow hammer.
BXHoosier
BX24
Jan 21, 2018
509
626
Indiana
Plumbed the heater today. The 3-way valve lets me select sending coolant to the heater or bypassing it back to the engine. A simple bracket and a hose clamp holds the valve. I reused the factory bypass hose to connect the valve to the water pump. All that’s left is to refill and bleed the system.
F2E71B47-2B4C-4AA2-B3A4-9A9534450312.jpeg 905F09A4-22E0-4714-9738-AB3FED70402C.jpeg C5492534-C5B2-42C1-BEA5-27F13EAF66F9.jpeg 5ECA14A1-792F-496A-AC60-FD78F06B7434.jpeg
bird dogger
Vendor Member
Feb 24, 2019
1,765
1,747
North Dakota
Found them at Menards. One probably would have been enough light.
Same lights I use in my home made cab. These lights are great!!
View attachment 89692 View attachment 89693 View attachment 89694 View attachment 89695
Now that's a neat installation of your 3-way valve!!
OrangeKrush
Nov 15, 2020
1,044
517
Indy
I love this build, pics info, very detailed slow steady well thought out build! I think you'll get your time and moneys worth this year!
BXHoosier
BX24
Jan 21, 2018
509
626
Indiana
Thanks OrangeKrush. Hopefully, I get to use it some this winter but not a lot. It will definitely be nice to be out of the wind when I’m clearing the driveway at 5:00 AM.
It was 32* F this morning when I pulled the tractor outside to test the heater. After running for about 30min, the temp in the cab was 62* F measured with a thermometer laying on the steering wheel. CCA16E4F-774E-4047-B190-FCD2741BA73C.jpeg
leveraddict
Apr 1, 2019
905
594
NEPA
How about a pic of the back of the tractor! I see something interesting back there!
