New Motor Advice
Big Iron
Bx2230 loader, box blade,post hole digger, mower
Aug 20, 2022
Alabama
I own a BX2230 looking to buy a new motor. Where is the best place to purchase one?
4,908
'best' ? I think Kubota, though would they have one in stock ?
Hmm, 15 year old tractor ? Does anyone have a complete, drop in engine on the shelf ?
Price of totally new vs rebuild ??
do you know the history of your engine ?
2,921
1,383
REPLACEMENT ENGINE D902E3BX TIER4 (BX2230D) part number 1G826-02001 is in stock at multiple warehouses and ready for shipment.
4,908
gee, looks like they've used that engine for decades ! Only about $5K USD too !
It'd actually be cheaper than rebuilding the Buda BD153 in my forklift.........
hmmmmmmmm... great another potential 'winter project'..
Big Iron
Aug 20, 2022
Alabama
Thanks for the help! I’m going to go to the local dealer in the morning and talk to them about A new one. Appreciate the Part number whitetiger.
Pau7220
Aug 1, 2017
785
278
Scranton, PA
Instead of going through the parts department, make sure to see a salesman for the wholegoods price …. if EPA regulations didn’t screw that up too.
Pau7220
Aug 1, 2017
785
278
Scranton, PA
Pau7220, please explain why the different pricing between the 2.
Here’s the best answer from 2 years ago.
old and tired
L2800 HST; 2005; R4
Reading that link and found that engines might not be sold through wholegoods any more, just through the (jacked up) "parts department": https://www.orangetractortalks.com/forums/threads/l5240-needs-an-engine.47073/#post-417415
I do not know for sure if this is true but a salesman will know...
Big Iron
Aug 20, 2022
Alabama
I got the new motor installed and it is blowing back smoke and no throttle response just like the old motor. The tractor has a new fuel pump and filters. And good gas. What could probably be the problem?
RBsingl
Jul 1, 2022
409
428
Central IL
Air intake system restriction issue? Something in the tractor putting an extremely heavy load on the engine when it should be unloaded?
Rodger
4,908
this...
is really sad...go to the expense,time and effort and have the SAME problem !!
I agree with Rodger, either air starved or under a huge load.
does it just 'idle' (RPM ??) ?
does it sound like it's 'under a load' ?
any way a hydraulic valve is stuck, 'loading' the engine down ??
or stuck in gear with parking brake on ??
pulling at straws as long distance diagnosis isn't easy...
Big Iron
Aug 20, 2022
Alabama
this...
Big Iron
Aug 20, 2022
Alabama
OK I found the problem!! It was a clogged exhaust. Cleaned it out and it runs great. Thanks for all the posts. That one really had me stumped.
Reactions: 6 users
RBsingl
Jul 1, 2022
409
428
Central IL
Congratulations on finding the issue and glad you got it figured out!
I thought about an exhaust restriction but I thought with the black smoke it was probably an intake issue but if it can't exhale it will over-fuel also due to too little air for combustion just as you found.
And thank you for coming back to post the solution. Far too many threads end up with the original poster disappearing into thin air; someone in the future is going to come across your thread and will quickly find the solution to the same problem with their equipment.
Rodger
4,908
grr.. clogged exhaust !!! THAT is a common problem with 2stroke weedwhackers made by Stihl as the 'spark arrester' plate plugs up.
Never thought that to be your problem....
Agree with Rodger, GREAT that you posted the solution !!..
so now what do you do with the original engine ????
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
606
468
central ny
I had what you describe with my stihl 170 chainsaw. I use their oil and 91 alcohol free gas. Finally took the arrestor out after cleaning several times and it runs great again without it.
Bill
