B2650 rear work lights
2650fan
B2650TLB
Jun 28, 2022
65
CT
At rear of tractor there are 2 wires marked work lights. How do you turn them on? Assuming one side hot and other ground?
Thanks
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
I believe it will be switched with the ignition switch. Volt meter or test light will tell you which one is which
BetterThanAShovel
B2650, BH77, SG0660 grapple, pallet forks, Bobcat 60" box blade
Oct 5, 2021
128
51
What he said. I used that connection to add work lights to the ROPS. I ran that wire into a plastic box and added the switches right there on the ROPS so I didn't have to run anything to the front console.
2650fan
B2650TLB
Jun 28, 2022
65
CT
Yes tried with light and voltmeter
No love, any ideas as to where fuse is?
Stmar
B2650HSDC
May 23, 2017
929
47
Buffalo, Wyoming
I don't know if your model is different from the CAB model. In the CAB model the plug for the switch is tucked under the dash, left side where the front light switch is, there are knock outs. You basically have to loosen the dash and you will find it taped to the wiring harness.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
Thanks
Hello 2650Fan,
I was looking to add rear work lights too. We have to keep in mind not to install anything with more than a 10 AMP draw. That is what the circuit is rated for. A higher draw might burn out wiring before the fuse blows. In looking at different brands of lights, I noticed that suppliers are not always accurate when they state the unit's draw. We have a 120 Watt max total on the lights we choose. I am just not sure how much light we are going to get out of that.
BetterThanAShovel
Oct 5, 2021
128
51
Hello 2650Fan,
With the simple LED lights available on Amazon, you can get pretty far. I bought ones that looked appealing and then measured their wattage on my bench and found it to be FAR BELOW what they had stated. I've got a large lightbar facing forward and 2 spotlights facing backwards and I'm pretty sure I'm barely over 5 amps. Just my experience, not any kind of guarantee to anyone else, YMMV. But it gives me ALL of the lighting I need.
19thSF
Mar 1, 2020
408
123
Hello betterthanashovel,
Would you mind sharing the brand and model number purchased.
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
Same !
BetterThanAShovel
Oct 5, 2021
128
51
What....share something about my tractor?? Oh, you'll never get someone to take you up on that offer in THIS forum! :)
Here are the links to the lights in Amazon:
Here's also a link to replacing the light bulbs in the front of the hood (better lighting and less wattage):
And here's some pics of it mounted on the ROPS.
PXL_20220902_145357682.jpg PXL_20220902_145424747.jpg PXL_20220902_145351527.jpg
I was gonna take a pic of them on last night as I was working anyway...but I've discovered that pics really never do it justice because the camera automatically changes the exposure to make everything brighter. But really, it's great lighting.
Hope that helps.
Rob
19thSF
Mar 1, 2020
408
123
View attachment 86431 View attachment 86432 View attachment 86430
Hope that helps.
Rob
Thank you!
lynnmor
B2601-1
May 3, 2021
1,445
1,159
Red Lion
Hope that helps.
Rob
I did the same lights and mounted them with magnets.
2650fan
B2650TLB
Jun 28, 2022
65
CT
Thanks all for responding
Fuse #9 was bad….moving on with installation
kamaveles
USA Buffalo
The installation and connection of the marker are directly dependent on the width of the unit's grip and the driving method. I don't think you can figure it out on your own. Therefore, I strongly recommend contacting qualified specialists first. Btw, I repair agricultural machinery in my garage on my own. I started using 5 Modes Vont LED Tactical Flashlight for additional lighting last month. I don't want to brag, but I am doing it well. However, I broke several cars before I got the hang of it.
  • Dislike
3,681
Would you mind sharing the type of magnets you used and how it's holding up?
Here's what I used...they work great and haven't budged in 2 years. I did have to cut the stud down a bit in order for them to work correctly with my light brackets...no big deal.
These magnets are very strong and take significant effort to remove. But, you can reposition them wherever you wish.
