What he said. I used that connection to add work lights to the ROPS. I ran that wire into a plastic box and added the switches right there on the ROPS so I didn't have to run anything to the front console.I believe it will be switched with the ignition switch. Volt meter or test light will tell you which one is which
Yes tried with light and voltmeter
No love, any ideas as to where fuse is?
Your guess is correct. I checked mine before I installed my lights.My guess would be fuse #9
Hello 2650Fan,At rear of tractor there are 2 wires marked work lights. How do you turn them on? Assuming one side hot and other ground?
Thanks
With the simple LED lights available on Amazon, you can get pretty far. I bought ones that looked appealing and then measured their wattage on my bench and found it to be FAR BELOW what they had stated. I've got a large lightbar facing forward and 2 spotlights facing backwards and I'm pretty sure I'm barely over 5 amps. Just my experience, not any kind of guarantee to anyone else, YMMV. But it gives me ALL of the lighting I need.Hello 2650Fan,
I was looking to add rear work lights too. We have to keep in mind not to install anything with more than a 10 AMP draw. That is what the circuit is rated for. A higher draw might burn out wiring before the fuse blows. In looking at different brands of lights, I noticed that suppliers are not always accurate when they state the unit's draw. We have a 120 Watt max total on the lights we choose. I am just not sure how much light we are going to get out of that.
Hello betterthanashovel,With the simple LED lights available on Amazon, you can get pretty far. I bought ones that looked appealing and then measured their wattage on my bench and found it to be FAR BELOW what they had stated. I've got a large lightbar facing forward and 2 spotlights facing backwards and I'm pretty sure I'm barely over 5 amps. Just my experience, not any kind of guarantee to anyone else, YMMV. But it gives me ALL of the lighting I need.
Same !With the simple LED lights available on Amazon, you can get pretty far. I bought ones that looked appealing and then measured their wattage on my bench and found it to be FAR BELOW what they had stated. I've got a large lightbar facing forward and 2 spotlights facing backwards and I'm pretty sure I'm barely over 5 amps. Just my experience, not any kind of guarantee to anyone else, YMMV. But it gives me ALL of the lighting I need.
Would you mind sharing the brand and model number purchased.
Thank you!What....share something about my tractor?? Oh, you'll never get someone to take you up on that offer in THIS forum!
Here are the links to the lights in Amazon:
Here's also a link to replacing the light bulbs in the front of the hood (better lighting and less wattage):
And here's some pics of it mounted on the ROPS.
View attachment 86431 View attachment 86432 View attachment 86430
I was gonna take a pic of them on last night as I was working anyway...but I've discovered that pics really never do it justice because the camera automatically changes the exposure to make everything brighter. But really, it's great lighting.
Hope that helps.
Rob
I did the same lights and mounted them with magnets.What....share something about my tractor?? Oh, you'll never get someone to take you up on that offer in THIS forum!
Hope that helps.
Rob
Would you mind sharing the type of magnets you used and how it's holding up?
Here's what I used...they work great and haven't budged in 2 years. I did have to cut the stud down a bit in order for them to work correctly with my light brackets...no big deal.Would you mind sharing the type of magnets you used and how it's holding up?
Thank you very much!Here's what I used...they work great and haven't budged in 2 years. I did have to cut the stud down a bit in order for them to work correctly with my light brackets...no big deal.
Everything should be in this post: LinkWould you mind sharing the type of magnets you used and how it's holding up?
