11,718
Actually, in my case, yes. Short of taking out numerous mature trees I have no desire to take out, there were, and are, pretty hard limits on machine size.
If you’re ever in central NC area, have a bit of extra time, and are really interested why just a few of inches width can be a deal breaker, shoot me a PM and I’ll be glad to give you a tour of our place. Only 70 acres so wouldn’t take long unless you wanted to walk it instead of riding in the Mule. At some point, “just a little bigger” is too big.
Based on the photos I’ve seen of your quite lovely place, looks like you have many wide open spaces. I think our property is lovely as well, but wide open spaces… not so much.
Thanks for offer, that's very kind. You clearly have a much better idea of your needs and thought it through and made the best choice for you and your property. I wish I'd taken a shorter path to my final destination, but sometimes you have to get it wrong in order to get it right.
11,718
Took the roof off to install radio & speakers. Also going to hardwire my LED beacon and Reflectix underside while I have it off.
https://www.orangetractortalks.com/...dio-to-a-kubota-cab-tractor.56484/post-574816
That's awesome. Are you going to add insulation in addition to the Reflectix. I'm not familiar with that product but will check it out. I would like to do something similar to my tractors, both for cold and for heat. I was thinking that a cellulose based insulation would be a good choice.
pokey1416
Jun 24, 2020
572
884
SW Michigan
From what I remember reading there is not a whole bunch of room so I think everyone uses the Reflectix.
MountainMeadows
Jun 6, 2022
219
290
Poconos, PA
I finally had a slow spell at work which gave me a little free time to add the Standard Features that should have been "standard" on the Standard L2501.........
First up: The L3302 floor mats.
Next: The right side handle.
Following the RS handle: Bucket level gauge
And finally the bolt on bucket cutting edge.........This will come in handy to scrape ice + snow off my parking lot this winter.
With a little time left in my day and some scrap 3/16 steel plate I started fabrication of a hydraulic pump skid plate.......
Reactions: 7 users
drumminj
L4701, Mule 4010
Nov 4, 2021
156
119
TN
Edit: Basically the same as NCL4701 said above...being in TN, it's not surprising we have similar topography and needs.....my original reply below as well.
Because the additional 6.3" of length and 7.3" of width would have been a deal breaker for you?
You can make this comment over and over for each step up. At some point it's big enough :).
I see your point but I'd suggest looking at it from another perspective -- the argument you make from the L4701 to MX is the same as one can make from the L3901 to the 4701. The extra 45% lift capacity for the 4701, extra weight, and bigger frame were totally worth it. Another step up would have been too much IMO. Could it work? Sure. Is the MX a good deal compared to the 4701? Absolutely. But it already feels tight in the trees - the extra width and length would make it even more difficult to turn around and work the grapple, mower, and rake in tight spaces.
it'd be worth taking a good look at both if you're in the L/MX market.
Absoultely agree it's worth looking at both. But I don't think it's fair to expect that the MX is the right choice for 100% of buyers.
11,718
And in truth, the width is a non-starter because the rear wheels are adjustable for width. It makes no difference to me what folks decide to buy, and it's a good thing that you're happy with the L, but I really don't see how an MX would be a problem for someone who likes and has an L.
You're absolutely right. I kind of apologized to @NCL4701 for my presumptive comments. We all have our own wants, needs and ideas. It's good to get the chance to compare different models on the lot, to get a sense of the size differences, but we don't typically get to use them on our properties unless we buy them. Many of us will never know if a different sized tractor would be better for us until we make a change.
The jump from a BX to an MX seemed massive at first for me, but I soon got used to the much bigger tractor. Now an MX feels small to me. I'm good friends with the manager at the local Kubota dealer, and I think he thought he was doing the right thing selling me a BX back in 2016, but in truth it was never enough tractor for my needs. He ended up buying that tractor from me for his cabin by the lake and maybe that was his plan all along! :LOL:
GrumpyFarmer
5,012
Yesterday, I bought a middle buster plow. The plan is to dig potatoes the next couple of days. View attachment 85989
I just used mine for first time today…way better than digging by hand…followed behind with pitch fork and put in buckets.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
666
695
Indiana
I used mine to dig out 5 bushels, mostly Kennebacks. I had my top link at the shortest length; my thinking was to make it dig deeper and more aggressively. I didn't destroy too many. There will be some more ready next month.
GrumpyFarmer
5,012
I just ran my all the way down on the 3pt hydr lever…i did not split or poke a single one that we found that way. I did not know it was back there for that matter. It exceeded my expectations.
MOOTS
MX6000
Jun 27, 2019
2,203
2,770
Canton, Georgia
Apparently I have been slacking on the FEL grease. Found a missing pin keeper bolt. Turned out to be a stuck/seized pin. Mapp gas torch, penetrating oil and a BFH wouldn’t move it. Round 2 tomorrow, maybe.
Finally getting back to this. All I can say is, grease your loader pins!!
Looking at the pin, looks to have some rust in it, seized to the link, not the ssqa plate. Heat, oil, hammer, repeat. Finally got it out enough to put the pry bar in keeper hole and got it twisting, then put some tension with strap. Really started moving then. All of this with loader arm hard against tree.
  • Sad
5,166
Ever wonder what is going through the child's mind as she sees you beating on that tractor attempting to remove the pin?
MOOTS
MX6000
Jun 27, 2019
2,203
2,770
Canton, Georgia
That’s my son. But yes, he heard the tractor start and the wife said he came running so he could see. Watched till I was done.
5,166
I just guessed at his gender assuming that I had a 50% chance of getting it correct. I take another guess, he is about 2 1/2 - 3 years old?
7,304
Matt - somewhat similar, I had an audience while I mowed yesterday.
My youngest “son” so to speak. His first experience with the tractor up close.
He followed me around at a distance. I probably missed a few spots…..😉
radas
Mar 21, 2022
719
834
Thanks for the reminder, I've been sticking with the every 10 hour schedule. Looks like you had a hell of a time with that pin 😔
My neighbor stopped by the other day and I mentioned wanting to get rid of a pile of crushed limestone I had from my gen pad project. He said his RV Pad has sunk a bit and needed some of I had no use for it. Made 2.5 trips down and cleaned off my driveway. He still needs a hell of a lot more stone, but I was able to help put a small dent in it.
I didn't put much effort into spreading, he insisted on raking it out himself so I put the loader in float a few times and back dragged the pile. Good enough.
MOOTS
MX6000
Jun 27, 2019
2,203
2,770
Canton, Georgia
I think this was previous owner neglect. Though, I have put about 75 hours on it.
Was probably in a hurry and said I’ll get it better next time…. Next time… next time… now we are here. Lol.
Hopefully dealer has on tomorrow. I’ve got 4 trees laid out to cleanup and firewood to start!
