Hey everyone, I think I got duped pretty bad on my recent purchase. Looking for some guidance here, 4X4 is, front wheel are not spinning at all. Found that there was no fluid in the front axle whatsoever. So filled it up and then noticed it pouring out at the differential sleeve. Pulled the sleeve and noticed that the rod or drive shaft that connects from the rear to the front completely missing and the spline at the front differential wiggles and moves freely and does not rotate when the front wheels are turned.
Here is a video of the front differential and what I found - definitely doesn't look normal to me:
https://youtube.com/shorts/Mri6_UnY1kY?feature=share
Thoughts, rebuild required? Where should I begin? Thanks for your help!
