L2501 Modifications
Dieseldonato
Mar 15, 2022
728
439
Pa
Changes like that are best left to a pump shop thay can flow the pump amd make sure all cylinder are pumping the same. Doest take much to screw something like that up.
#40Fan
621
450
If you watch this video, you can see what he did to get more fuel.
As for the rack adjustment, it doesn't look like anything can be done other than opening up the slot that the rack travels in.
Dieseldonato
Mar 15, 2022
728
439
Pa
Unless your going for some extreme power upgrades swapping the plungers and barrels isn't nessisary. And with the same point I made as above you don't really know if the new parts are putting out the same cc of fuel as each other. Hence why there are shims.
joham524
L2600DT
Dec 8, 2023
Sorry to reply to an old thread but looking for help. I have a L2600DT with the D1403 in it. My tractor is rated for 26 HP but the L3000 is rated for 35 with the same block. Is it safe to assume the only difference is the timing adjustment and fuel? I'd make the mod if I felt safe implementing.
Thanks
Rdrcr
Vendor Member
May 7, 2021
773
972
WA
Got a link you the parts? Really like that!
Sure!
They’re a really nice upgrade and sturdy floor mat.
Mike
