sawmillers, blade lube
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
Just purchased a woodland mills saw mill. Great mill but having trouble with the blade lube. Been using water with dish soap and it creates a sludge on the wood that if it is not brushed off, it dries hard like concrete. Can't grasp using diesel fuel on wood that may be stained or painted but others use it. Any one here use something they like?????
5,680
Yes, Winter WW fluid... only type I have here. Some say the pink, summer is better (has ?? to help clean bugs off..._
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
I only use water. But I also don't saw pine, or anything else with sticky sap.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
217
215
Heart of the Catskills
My son-in-law uses straight water for his Wood Miser in the warm weather. He's been cutting hemlock and pine for the most part with no problems other than an accumulation of wet saw dust inside the saw casing.
Magicman
Oct 8, 2019
5,888
8,878
Brookhaven, MS
knotholesawmill.com
I have been using 2-3 oz of liquid Cascade (light green jug) per gallon of water for 20 years. It does not make suds so it's easily mixed. I have sawed well over 2 million bf using Cascade.
2412 bf of Southern Yellow Pine framing lumber sawed yesterday morning.
I recommend that you check out "The Forestry Forum" for sawmill related questions, and Congrats on the sawmill.
jyoutz
Jan 14, 2019
3,379
2,419
Edgewood, New Mexico
The old timers used kerosene. It removes the wood sap. The old loggers even carried bottles to lube their crosscut saws.
Magicman
Oct 8, 2019
5,888
8,878
Brookhaven, MS
knotholesawmill.com
Which is why many sawyers use Diesel. A drop sprayed on the blade every 2-3 seconds or dripped onto a wick is all that is needed. I keep a spray bottle handy and occasionally on a lightening struck or a Longleaf Pine log a squirt may be needed. No it's not enough to be concerned with stain nor smell.
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
Tried the diesel fuel diluted with paint thinner. Works good, no more drying like concrete but I haven't cked the effects of staining or clear coating. Maybe nest month. I've already got 2 stacks of lumber 4 ft deep and over 6 feet high in the 40 by 60 metal building. No more place to put it. Will just have to tarp the rest of it outside. My converter supplier has already ordered some 1X4's.
