Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
I have a B2410 with a RCK60-24B MMM. I added a Kubota grass bagger that incorporated a drive shaft PTO to the blower. The PTO is powered by bolting it to the shute side mower deck pulley.
Here is the problem... when you mount the blower PTO to the top of the pulley it completely covers the grease fitting that is on top of the pulley spindle. This grease fitting is where the top bearing on the mower blade gets it's lubrication. There are two grease fittings on this pulley spindle shaft one on top, as I described, and the other under the the pulley. The bottom grease fitting ONLY lubricates the lower spindle bearing.
With the PTO mounted on top of the blade pulley spindle.... there is NO WAY IN HELL TO LUB THE TOP SPINDLE BEARING.
Guys... am I missing something here....?
