Dumb question but I have to ask
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
994
1,340
Pittsburgh
Yes, I think it is say to assume that the bearing is seized.
5,681
'Hello, Houston, we have a problem...'
looks like it's been 'deep sea diving ' ?
I'd pull EVERY plug and drain EVERY 'oil'......
..hopefully a nice project to work on.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Where is the hub that the cv shaft connects to? Agree it looks ugly, but I have seen far worse still driving…
Dieseldonato
Mar 15, 2022
728
439
Pa
Heck you can see the shaft is sitting off center... time for a tear down.
3,185
1,604
Howdy y’all,
The rear left tire on my RTV 1140 isn’t free spinning the universal joint is snapped in half. Is it say to assume the bearings are frozen behind the wheel. Anyone else experience this? Any advice or suggestions would be greatly appreciated.
thanks
There are two bearings in the axle housing, at least one of them has failed. You will need to remove the rear axle assembly from the unit and drive the shaft out toward the inside. There are two bearings with a spacer between them and two seals, one on each side.
