4,729
I made up a dolly the other day after watching a guy on youtube. If you dont mind me asking how do you get the backhoe to come off the tractor without using the stabilizers? Every time I have tried the tractor's rear tires have wanted to lift up which caused me to abort. Everyone on youtube made it look so easy but so far I have not been successful.
I'm unsure as to why you are asking this. Is it because of the strap keeping the stabilizers from drifting down?
I use the stabilizers for removal and installation. I only tie them together with the strap when storing the hoe or when its mounted on the tractor and not needed. It keeps the stabilizers from drooping over time.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
Before it rained this weekend I finished the rough grading on the north side of our house. I am planting a new lawn there. Glyphosate then ripped everything with the box blade.
The challenge was working in a small area. In the pic you can see the condensing units along side the house. On the right where the vertical 4x4 and cedar pole are is a 3' drop off. My grape arbor used to be there. I dropped 8 yds of topsoil to try and level things out a bit.
The box blade with the top n tilt is wicked. Just tough maneuvering in the small area.
Oh, the trench for the wiring to the woods is all covered up now. You can see the 2" pvc pipe coming out of the ground at the far end of the house.
I couldn't seed because the ac guys are here today and will be working there for a couple of days. Some final hand raking after they are done and then we seed.
My major accomplishment - I didn't hit the house or ac units with anything :)
Reactions: 9 users
PortTackFarm
L3560 LE (ROP's) w/ LA805 FEL, LP RCF 2072, BB2572 and WoodMaxx WM-8H
Jul 2, 2021
146
160
The Ville and The Farm (KY)
I need to seed grass at our farm, about an acre, but I'm waiting til Fall. With the current pricing for weed / grass killer, seed and fertilizer, I can't afford to do it too early and risk losing it to the summer heat and drought. This is a recreational property so we're not there all the time to water it and move sprinklers around on a daily basis. Good luck with your grass.
fj40dave
Sep 24, 2009
424
257
Yelm, WA
Started the power-to-the-shed, patio, then the other shed project for a customer today! Overall, will be ~200'
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
Fall is the best time! I don't have much of a choice, we are looking to list our house asap and I need a lawn on that side :).
I planted a new lawn in the front last fall (glyphosate, rip with box blade, remove all rocks, lime, fertilizer, till and drag harrow). It worked out great and I have enough of everything left over to plant this year.
I do have sprinklers set up and plan to water once or twice a day depending on the weather.
S-G-R
LX3310
Jun 17, 2020
1,210
2,630
PEI Canada
Checked the fluids, greased the loader and was planing on mowing grass. After a long and humid day, a cold beer won over the lawn.
dlsmith
BX2230, LA211
Nov 15, 2018
1,260
827
Goshen, IN
I used the BX to suspend the seat pan of my niece's JD LA125 while I gave it a coat of JD green.
Chanceywd
Mar 26, 2021
685
606
central ny
I used the BX to suspend the seat pan of my niece's JD LA125 while I gave it a coat of JD green. View attachment 82596
Nice! Now if you could show how your pole attaches to the bucket that would be nice too. I was thinking about making something like that and looks like a good idea!
Bill
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,031
854
canada
I also like the boom, looks like a handy thing. I am sure it works well for your application. Not to be negative, but if I was to build a bit heavier version, I think I would turn the angle 90' to rest it on the lip of the bucket, to provide a bit more support, then make gussets down to the pole. I can not see if you did or not, but I would reinforce the top of the bucket, to spread the force out along it. Also I don't know the capacity of the link connecting the turnbuckle to the boom, but I would be inclined to use a shackle.
I also like that grill guard, looks very well made. The paint on the floor pan and the guard look excellent.
dan_m
BX2380
Jul 9, 2020
197
Georgia
yesterday I used my new "radiator genie" to clean out the series of coolers on my mx5400. It worked very well.
Then i put the lane shark on and worked on my shooting lanes and roads for a while. Deer season start soon.
I wonder if this would do the same (note the nozzle is different) https://www.amazon.com/Flusher-Powe...ment/dp/B09J29FM4Y?ref_=ast_sto_dp&th=1&psc=1
I had one of the all plastic ones with a small fan-like end like the radiator genie but it broke (plastic split) after one season.
I have one of these to flush the hot water heater on my travel trailer.
radas
Mar 21, 2022
719
834
Figured out which BB I wanted to buy after many hours of research. Originally I was set on buying the EA and the decided to do additional research. Basically I wanted the heaviest 54-60" BB I could get my hands on without modification to serve as adequate rear ballast and for grading/scraping activity.
I decided on a woods BSS60. Called around to all the local dealers and nobody had anything smaller than a 65" in stock which is overkill for my LX. I lucked out and found a local dealer with a BSS54 woods BB in stock that is STOUT. Weighs shy of 500lbs and had a reinforced top link area with 4 blades. Got it for just a hair over $1k. Also decided to cancel my EA Pallet Fork order that was still at least 50 days out and purchased a land pride pfl1242 fork assembly which is more than enough for my LX as well. All in, I was less than $2k OTD and didn't have to wait (except for having to wait until my truck arrives next week so I can pick them up).
Reactions: 6 users
Magicman
Oct 8, 2019
5,807
8,619
Brookhaven, MS
knotholesawmill.com
Bushhogged today.
I have the Bush Hog 3008 set up in a semi-lift configuration. Speeco Cat3 Quick Hitch to adjust the cutting height and three trailing wheels to avoid high centering
Magicman
Oct 8, 2019
5,807
8,619
Brookhaven, MS
knotholesawmill.com
Replaced my gear shift boot today. $14.97 from eBay with no tax and free shipping. That beats $32 from Kubota. I got the old one from Kubota in October, 2019.
dlsmith
BX2230, LA211
Nov 15, 2018
1,260
827
Goshen, IN
Bill
Here you go. I fabbed it up out of some 2" and 1 1/2" square 11ga tube, 2" X 1/4" bar stock, 3/4" square bar stock and some 2" angle that I had laying around. I already had the clevis installed in the bucket, so I bought a turnbuckle at TSC to secure it to the bucket. With the clevis, it puts very little strain on the cutting edge, so it won't get bent.
It's really handy for lifting items that aren't too heavy, and I use it pretty often.
Reactions: 6 users
radas
Mar 21, 2022
719
834
Man, you must have finally received that tax refund (and all the interest they added on)!!!
😂 How'd you know?
Yeah I finally got it, 1 year and 2 months after filing a 1040x, they sent me my dependent credit balance owed with a whopping $100 of interest 😂
I also sold another vehicle to Carvana last week and took advantage of their negative equity purchasing scheme 😁
radas
Mar 21, 2022
719
834
View attachment 82658 View attachment 82659 View attachment 82660 View attachment 82661
That's neat, looks relatively easy to fab up too with metal scraps. Nice work!
dlsmith
BX2230, LA211
Nov 15, 2018
1,260
827
Goshen, IN
In case you didn't notice, I plug welded the 1 1/2" tube to the 2" angle on the front side to give it more strength. If you enlarge the picture, you can see the welds.
jyoutz
Jan 14, 2019
3,340
2,379
Edgewood, New Mexico
We had a fair amount of rain recently to settle the dust, so I rotary cut about 5 acres around the house and outbuildings.
