I went to put my factory steel wheel spare tire on my truck (2017 Ford F250) a couple weeks ago. The lug nuts bottom out on the lugs before the wheel is tight on the hub. I have aftermarket aluminum wheels and the lug nuts designed for the aftermarket wheels.
Just an FYI if you put aftermarket wheels on your truck. Your spare may be unusable. Luckily I did it in the daylight and could see that the spare wasn't tight on the hub.
