UDT Oil screw up
ZipFunk
2380, T1880
Sep 10, 2021
15
I just realized I put UDT oil in instead of 10W30 for my oil change in my BX2380
I have 3 hours use with the oil.
Clearly I need to drain and change the oil and filter ASAP but is there anything else I need to do
2,817
Cross your fingers maybe? LOL
My guess is you will be OK, but time for the heavyweights at OTT that actually know something to chime in.
Great that you realized your mistake rather quickly...
Edit: Are you using diesel rated oil? I use 15W40 shell oil in my tractors. Just asking to be sure...
WoodKutter
L4600 John Deere 750, John Deere 420
Apr 15, 2022
95
55
Vermont and Northern Maine
Yup, change immediately. If the engine is cool, I would not start it to warm the oil. Drain overnight to get virtually all out. New filter and diesel (CK is current) oil, 15-40 sounds good.
2,439
i'll second woodkutter...
now.......... if you are a bit paranoid ............use a good diesel oil and then CHANGE it again after about 10 hours........ by then you will have removed 99% of it.
5,949
No issue at all, if anything you've just cleaned it out.
Carry on!
Reactions: 6 users
Nicfin36
Jun 19, 2019
1,016
465
Decatur, AL
I worked for a tree company and our pusher engine for the truck hydraulics was a Kubota engine. My foreman would use Chainsaw Bar Oil in it when it needed oil and he did not have any motor oil for it on hand. It never missed a beat.
ZipFunk
2380, T1880
Sep 10, 2021
15
Hi guys,
Thanks for all the advice.
Oil has been drained for a few hours and changed. New oil filter too of course.
I didn't notice anything different or any sounds other than the usual so I'm assuming there was not enough time to wreck anything if at all.
I won't be as bone headed the next time.:LOL:
5,253
There are some folks who use a product called Rislone, it's suppose to clean the engine just before an oil change. That's what you accomplished without that product! ;)
3,458
1,929
Hi guys,
You are less bone headed than the guys skipping oil changes altogether!
Other than a few additives your UDT oil is similar to your engine oils.
To put your mind at ease have a look at this article:
RalphVa
738
320
Charlottesville
Think UDT is about 20-25 weight but not diesel rated to keep soot in suspension. Think your Kubota probably allows 20w oil use in the engine (diesel rated). Problem is you're not likely to find any diesel rated 20w.
You didn't need to change the filter. Could have just taken it off and drained oil from it and put it back.
I'd use a 0,5 or 10w30 diesel rated oil. Can get it.
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
183
137
Westford, Massachusetts
shelkol.com
I think you have totally destroyed your tractor. I would be willing to come pick up the remains for free! lol
4,180
Engine oils and hydraulic/gear oils are very different animals. Engine oil is full of very important additives. The presence of those engine oil additives in a hydraulic system or drive line do not cause significant problems. The absence of those engine oil additives when a hydraulic oil is used in an engine WILL cause very significant problems if used for any length of time.
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
153
149
Demotte, IN
Little different but I once put in 1 qt of tranny fluid by accident in with the other 3 or 4 quarts of oil when changing the oil in a gas engine. Ran it the normal 10k miles between oil changes with no noticeable issues.
Mark_BX25D
Bx25D
Jul 19, 2020
1,655
1,178
That's an old-school trick for cleaning out a gunked up engine. Works well.
3,280
I’m not a fan of cleaning out “gunked up” engines. If the engine part isn’t moving….(like a sump-wall or valve cover, etc etc)…. why would I want to break all that gunk loose and send it flying thru my engine.? The parts which DO move…like pistons against cyl walls, and rotating shafts, rocker-arms, valves, etc…. they keep their operating surfaces clean by their basic action…therefore those mating surfaces are ignorant of any “gunk”…. unless someone breaks it loose and sends it thru all the bearings and clogging passageways, etc. etc.
2,817
My guess is since the OP only ran the tractor for two hours it is a non issue.
Time to say "good job" to the OP for realizing the mistake and correcting it, and that likely no future issues will develop.
