Do D1105 flywheel bolts need loctite?
ChrisRI
Kubota D1105
Apr 13, 2022
20
New England, USA
I dont know what the factory says thats why Im askin... I figure lots of Kubota guys here would have done rebuilds etc and would know
Dieseldonato
Mar 15, 2022
728
439
Pa
Remember to use an oiled torque....
Flintknapper
L2350DT
May 3, 2022
1,806
2,269
Deep East Texas
cool! I cant oil the threads AND use locktite tho, so add 20% to the torque setting? mor???
NO..........REDUCE the torque figure by 20% to allow for the lubricating quality of the loctite.
Most torque figures are set forth assuming a dry/clean fastener.
Dieseldonato
Mar 15, 2022
728
439
Pa
Factory application doesn't always follow the color scheme were used to.
Flintknapper
L2350DT
May 3, 2022
1,806
2,269
Deep East Texas
Very true. And in cases where dissimilar metals are used (steel bolts into aluminum for instance) galvanic corrosion often occurs and you really can't tell if the threads ever had a thread locker or not. Same is true of bolt threads exposed to coolant (usually around water pumps).
Some items that commonly have thread locking products are Flywheel Bolts, Pressure Plate bolts, Engine mounting bolts. Certainly not in every case....but worth looking into.
Diesel engines in tractors are notoriously vibration prone. I wouldn't say it is inherent....but they are not exactly balanced on a pin head, so adding loctite to certain fasteners is not generally a bad idea even if the factory didn't do so.
