woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
That's interesting, it does not call for it being changed on my L6060 at 50 hrs, but after seeing yours, I think I might do mine. The hst filter lists for 104.78 and the suction is only 54.84. I cut my hst filter open and it looked fine.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,522
3,706
PEI Canada
Took about six weeks to hit 50 hours on the LX3310 tonight. Did the oil and filters. Lost a bit more UDT then I expected and managed to get some of it on the garage floor so a normal service overall😆
radas
Mar 21, 2022
719
834
Pushing 7.9 on my LX2610 so far, about ready to get that first greasing out of the way 😭 how long did it take you to do the full drain, fill, and filters?
S-G-R
Jun 17, 2020
1,522
3,706
PEI Canada
Less than an hour. I had everything lined up and ready to go. Gave it a greasing and checked the air filters while the oil was draining.
7,070
Just a note for your guys doing 50 hour service.
The front axles on new machines are notorious for being low, and nearly dry in some instances.
Don't forget to check them if you haven't done so already...... :geek: :geek:
9,505
That's a great point. The local dealer fills them from the drain plug but I need to check the M6060 which came from a dealer in WY. I'm not sure about their due diligence yet. Thanks for the reminder.
ACDII
Oct 21, 2021
685
429
Illinois
Finished the digging yesterday with the Lil Mule, and got the new hydrant hooked up and buried, then got the L4060 out to backfill behind the barn. Those LED worklights I installed worked very well, the tractor though, not so much. I would have thought being a heavier, more powerful tractor it would have no problem moving the freshly dug soil, but nope, it struggled. The level indicator also fell off, and man does that loader bang a lot. The Lil Mule is far easier to use for back filling, but open cab, with lights on at night attract a LOT of bugs.
The Lil Mule (B2410) has finally reached and exceeded the 500 hour mark after 20 years of ownership and due for it's maintenance, and while at it need to go over all the bolts for the backhoe subframe. I felt a lot of shifting around while digging, so something is loose somewhere. I think the clock is slow because I sure used it a lot more than I think that clock says. I should probably time it to see if it actually is running hourly.
While at it, going to go over every bolt on the L4060 as well. I also smell burning oil still, but see no leaks and the oil level is the same. The joystick is also sticking on up curl, I can release it and the bucket will continue to curl.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
My L6060 was down 1.5 liters. The plugs were still painted over, so the dealer never checked them.
3,472
2,047
. . . I think the clock is slow because I sure used it a lot more than I think that clock says. I should probably time it to see if it actually is running hourly. . .
Our old mechanical tachs are like car odometers, except calibrated for hours at rated speed. If you run at half rated rpm, it'll only register hours at half speed.
5,867
Sunday's fix 'er up job after sewer line installation in January. No, I did not do the initial dig as I wouldn't have left it looking like it does in the first pic.
What a mess:
Box blade and landscape rake to the rescue (along with much tree trimming).
another happy customer. Thanks Kubota.
Reactions: 6 users
forky
Feb 23, 2021
309
332
Wisconsin
DD, it's nice to see that you pay a lot of attention to detail. It's becoming a lost art among the service industry providers today. I just bet you sleep well at night too!
Snowman7
May 20, 2020
394
287
Boyne Falls, MI.
And you could too. My neighbor on 160 acres just put the 46 acre section next to me on the market for $925k. It's a lovely spot and I'm sure someone will snap it up. I would love to buy it, but as a single guy on one income it's out of my price range. I've been able to enjoy it for the past 8 years without footing the bill, but it's disappointing that my neighbor, who lives in PA and who certainly doesn't need the money, has decided to sell it.
Wow, $20,000 an acre. No thanks, I love my home in northern MI.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Only 130,000 per acres. Ain't no poor folks in Pound Ridge, NY
$2,000,000
15.44 Acres
Rolling Meadow Lane, Pound Ridge, NY 10576
5,867
Thanks for the kind words Forky. I try to do a good job for people and find that if you're just nice to them, it sets the tone for the whole job...making the whole thing go much easier.
The funny thing about this job is when I showed up Sunday morning, the home owner came out wearing a hat with the logo of a farm that I used to work for (40 years ago). Then it dawned on me why this gentlemen seemed so familiar...we both worked for that farmer and I did remember him (he's in his 80's). We had some good laughs Sunday afternoon. We shared some pretty interesting memories from that farm.
There are still some good, honest people out there. You just need to be lucky enough to find them. I suppose that was the take home message from that job.
ejb11235
BX23S, Braber BBR4G 4'BB & LRM5G 5' rake, Redline 48" rock bucket, PFL1242
Jan 20, 2022
486
373
Seattle, WA, USA
Today I removed the backhoe from my BX23S for the first time. Mounted the three point hitch and the new box blade. Eventually put the backhoe back on. All that went relatively smoothly. The telescoping stabilizer bars makes it a lot easier to attach an implement ... I realized I could pull the pins, get everything attached, raise the implement, and with it in the air I can center it and then put the pins in the stabilizer bars. I am glad that I bought the telescoping bars right out of the gate and never once had to deal with turnbuckles.
EDIT: I suppose you can accomplish the same thing by disconnecting the pins or shackles on implement end, so the telescoping bars don't really provide as much of an advantage, provided you don't use cotter pins. Still, I thought it was a good example of "out of the box (blade)" thinking.
I played around with the box blade both on rough ground and on my driveway, then headed over to my future flower garden. I removed a fair number of larger rocks (>1 foot) and a bunch of small ones. I'd run the box with the scarifiers all the way down and then go back and carry the rocks to the side by hand. I don't know how well a landscape rake would handle the larger rocks, but I sure could use one now. Tractor is now parked though because I'm over-due on the 50 hour service and the engine oil filter isn't coming off easily.
IMG_20220607_132037_01.jpg IMG_20220607_150541_01.jpg IMG_20220608_125659100_HDR.jpg
drumminj
L4701, Mule 4010
Nov 4, 2021
156
119
TN
What did you top it off with? SUDT2? (I'm about to do my 50hr service and will be checking the same and expect to need to top it off)
old and tired
L2800 HST; 2005; R4
...The plugs were still painted over, so the dealer never checked them.
That would be a quick check, if the plug is painted over, it only has what the factory puts in it. Which is NOT much.
I think they put SUDT in the axle from the factory, I would drain whatever was in there (there's no filter so it just grinds up any metal flakes) and replace with Gear Lube; in whatever flavor you like... (75/90 80/whatever....)
