9,670
That would be a quick check, if the plug is painted over, it only has what the factory puts in it. Which is NOT much.
I think they put SUDT in the axle from the factory, I would drain whatever was in there (there's no filter so it just grinds up any metal flakes) and replace with Gear Lube; in whatever flavor you like... (75/90 80/whatever....)
I posted this back in February.
" I spoke with the manager at the local dealer and he stated that the tractors come from Japan with 80-90W in the front axle. They have to bolt on some parts that won't fit in the crate and top off with more 80-90W oil. He mentioned that they always recommend staying with 80-90W for the front axle because the viscosity is higher and it tends not to leak as quickly if a tear develops in one of the seals. "
I just removed the fill plug and check plug from the front axle of the MX and the smell confirms gear oil rather than SUDT. For the record, the level is right up to the bottom of the check plug hole. The local dealer always does a great job!
9,670
I was offered $100K for one of my acres in N AZ last fall.
If that acre is anywhere near the North Rim of the GC I'm interested! :ROFLMAO: The Kaibab Plateau is the best part of AZ as far as I'm concerned, just gorgeous. Just my opinion so don't get bent out of shape if you live in other parts of AZ. ;)
gs1s
L2501 HST; Rhinohide Canopy, Wicked Tooth Bar, Pat's Easy Change
Jan 10, 2022
10
I spent my day mowing my trail system and the area around my little wildlife pond with the 6 foot Landpride cutter. The pond is doing well after putting down the sodium bentonite. Water level rose 3 inches with the 1 1/4 rain last night. Very happy with the performance of both the L2501 and Landpride cutter. The ride is a lot nicer than I was used to with my B7100.
View attachment 81422 View attachment 81423 View attachment 81421
How does the 6' handle behind the L2501? Have same tractor and was considering a 6' but worried about performance. A neighbor just gave me(!) a 30+ year old John Deere (wrong color, I know) 5' cutter that will work for now.
ken erickson
Nov 21, 2010
1,301
2,280
Waupaca Wisconsin
So far I have been totally happy with the performance. I too was worried about how a 6 foot cutter would perform behind my L2501. I just returned from my land and spent two hours cutting blackberry brambles and other invasive species in my native seeding area. I cut in medium range (hst transmission) set the tach as close to the middle of the yellow pto band range. To be fair , I have not cut super high dense grasses. I have cut 12 to 14 inch high wet cool season grass. At that point I increased the rpm's to the high side of the yellow band. The type of cutting I do does not lend itself to high speed travel. Some have said 6 foot is too wide for my tractor, but to be honest I prefer the cutter being about 6 or 7 inches wider on each side.
gs1s
Jan 10, 2022
10
Good stuff. Maybe if/when this freebie JD 5 footer gives out I'll look to try out a 6 footer before replacing. Just in a weekend of use, I got into some thick bermuda and bahia (I'm in Texas), wet from morning dew, and felt like it was bogging down. I still need to fiddle with the setup.
If your L2501 is newer and close by, any chance I could convince you to measure the distance between the ROPS (inside measurement) near the hinge? Looking to order a RhinoHide canopy and my tractor is an hour and a half away. The increased seat time with my new (to me) mower plus 100 degree temps arriving this weekend means I need a canopy ASAP.
ken erickson
Nov 21, 2010
1,301
2,280
Waupaca Wisconsin
I purchased mine new in fall of 2019. I will measure it next time to the land. Will not be tomorrow , three new roofs being installed after a April hail storm. I should be down Saturday. Perhaps someone will chime in with that measurement before? :)
gs1s
Jan 10, 2022
10
Sorry about the hail and good luck with the roof installs. If you (or anyone else) could get that measurement before the 17th (next time I'm at my property), I'd appreciate it.
OntheRidge
Nov 1, 2020
434
504
The width at the hinge,. inside, is 35", just above the hinge plate is 35 1/2. Hope that helps.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,528
3,727
PEI Canada
Grabbed a couple gallons of UDT at the dealer to top up the fluid I lost during the 50 hour service.
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
146
252
St. Clair, MO.
Installed gutter drains today.
Reactions: 9 users
5,273
It was kind of a weird day. Took off work to take the camper to the dealer for a mandatory annual warranty inspection. I usually wait with it and do some computer work while I’m waiting. Got there and they said there was a mix up so they’d take it but it would be Tuesday before they could get it back to me unless we REALLY needed it for a trip or something. I could have gotten all stupid about it but they’ve been decent to us in the past and we don’t need it for a while so there was no reason to do anything other than drop it and head home. My father is in the hospital so I took him some stuff he wanted and visited with him a bit. Thought about going on to work but didn’t feel like it and had the whole day scheduled off so went home.
Got home about lunchtime and asked wife what, if anything, she wanted to do together. She said, “It’s your day off and I don’t have anything to do today that can’t wait until tomorrow so whatever you want. Might be a good day to look at Airstreams.” I say, “We’ve been together 33 years. You know I’m very literal and hints don’t work. You want to go look at Airstreams?” She, “No, that was just a suggestion; we’ll do whatever you want.” Me, “In that case I’m trimming trees.” She, “I’ll meet you outside in a little while.”
45 minutes later I hear the faint sound of the Mule starting. I took the pole saw and loppers but left her the Mule because I’m not a total jerk. Put down the pole saw and got my phone out. 30 seconds later it rings, “Where ARE you??” “Field by the road. East end.” “What are you doing there? Didn’t you hear I wanted to look at Airstreams?” “You’ve known me 33 years. You know hints don’t work. I smell like the inside of a shoe now. I’m trimming trees.”
So we trimmed trees. Apparently Golden Rain Trees don’t self prune, at least not quick enough for my liking. So we trimmed the dead stuff out of them. Then all the dead limbs and dead little trees along the driveway and a few around the yards.
Cleaned up about 80% of it with the grapple. Was planning to put the chipper on and chip some of the bigger stuff in place rather than cutting it smaller to fit down the trails to the brush piles and then hauling it to be chipped later. Wife doesn’t like me chipping alone (can’t really argue much with that) and she was looking pretty gassed (90* and humid) so the chipping will wait for the weekend.
If we still hauled brush with the pickup and piled it up to rot without chipping, I don’t know how much of this we would have done.
notaz3
87
87
ID
After 11 months of it being on order, today I took delivery of my new L3560. Still waiting on loader and bucket though.
Reactions: 6 users
3,226
Nope, I like the Kaibab also, but I live in the Phoenix area and my high country property is above the Mogollon Rim. (almost identical to Flagstaff elevation, trees, & critters, but without all those 2 legged varmints) :)
9,670
Nice! I worked for Ruger for a year and a half as a pistol engineer and was supposed to relocate to Precsott, but after a week there this time last year I just couldn't do it. Great money, good company, good people, but Prescott living wasn't for me.
Yesterday morning I was able to reserve a cabin on the North Rim of the Grand Canyon for three nights in October right before the North Rim closes for the season. I'm going to hike from the South Rim to the North Rim with my significant other. I was supposed to do it two years ago and had it all set up but COVID ruined that due to limiting park access.
Norman
LX2610HSD;LA535;LP 60" grapple; WC68 chipper; GB60 SW cutter
Sep 30, 2021
84
97
Georgia, USA
Did a little stone work for the raised garden area, only about a square yard, but it was a whole lot easier than a wheelbarrow and shovel.
Reactions: 9 users
9,670
Is that a custom seat cover or an off the shelf item? Thanks.
7,075
9,670
