Tractor seats
3,703
I just put that exact same "spring suspension system" (TRAC brand) on my SCAG Liberty Z mower.
A major improvement to the seat ride!
Yep…it took me awhile to get that knob adjusted “just right” to give me true suspension vs my weight…but it sure takes the “jolt” out of bumps and ruts.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I have the grammar air ride in grand l4760 hstc with the fore/aft kit. The part number is MSG75G/531 for the seat. You need to order it form a kubota dealer to get it with the riser that is required under the seat. You lose the swivel feature and if you want to run the pto without being in operator seat you lose the flip up seat and switch to run it. You can put something about 3 lbs or more on seat and still run pto without being in the seat. Just be careful! The seat made a huge difference in my opinion. Not as much travel up and down as original but not near as jarring. If you have a hydrostatic transmission the fore/aft kit is great but if you have a clutch you probably won't like it. The fore/aft isolator kit gives movement forward and backward with a gas strut like movement. The seat comes in cloth if you have a cab and vinyl if you don't.
Have you tried applying the park brake before you get out of the seat with the pto engaged ? That is what I do and the pto/tractor continues to run after I get out.
dgtvrpepair
L4760HSTC RTV-X1100c ZD1211L-72
Feb 10, 2020
53
29
Morrilton AR United States
No I have not. Thanks for the information I will try it. The original seat I had to flip the seat up and pull up on a lever under the seat to keep it on and that isn't on the new air ride seat.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,733
2,174
Western MT
My seat leans too far forward as well on my L2501. I've tried loosening the spring, but it bottoms out. I think I'll rebuild the seat bracket to make it a bit higher in front. I'm a lot larger than OP at 6'2" and 220, and it doesn't fit me either. Unclear who they made the seats for. Maybe really short people ... short people feel free to respond. ;)
3,703
The aftermarket seat I mentioned above has fore/aft, as well as ”tilt” and “recline” adjustments. The Armrests are also adjustable and stowable. (can you tell I’m happy with that seat?) ;)
6,189
If you can find one of these for a better price, snag it. https://www.surpluscenter.com/Brand...ic-Black-Seat-Black-Talon-440000BK-1-3208.axd
I got one of these a few years ago from RK (Rural King). They had them for the blowout price of $49 I think it was...maybe it was $99. Either way, It may have been an ad miss print but a bunch of us ordered them. They sold out quickly. In hind sight, I should've ordered 3 of them. Great seat.
Here's the seat...
found the original order...you can use the P/N possibly?
3,703
Here's the seat...
YEP! THAT’S THE ONE! GREAT SEAT!
6,189
sorry guys, I should've read the entire thread. I didn't realize that many of you had already mentioned the black talon seat.
OP- they are a good seat at almost any price.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
For that black talon seat is the safety switch saved or just jumped out?
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
41
KY
Here's the seat...
Does it rotate around for your BH77? I'd love to get one of these for my B3200/BH76 swivel seat!
6,189
Matt,
Yes, it does. The seat has a removeable top section (like a head rest in a car) that I forget to pull off when I'm hoeing in a hurry (and kneeling on the seat facing backwards).
There's also a handy storage flap in the seat back.
Some pics posted below for you that you may find helpful? Last pic is only to show that I turned the hazards sideways to make more room for spinning the seat. One of these days I'll remount them to outside of the ROPS (maybe).
6,189
Not sure who you were asking...
Here's my safety switch fix (on B2650). The switch stays mounted under the flip and pivot hardware and does not need to be touched (but as you can see, I did...ever so slightly) ;)
MattN03
Sep 5, 2016
222
41
KY
Matt,
My B3200 doesn't have those springs. I wonder if that's just a model improvement? Have you looked at adding a mechanical suspension seat base to the seat?
Do you have to remove the head rest for clearance when using the backhoe?
6,189
Nope. I'm not adding anything to the seat as it sits up high enough as it is.
and No. you don't need to remove the upper backrest. I only do when I'm using the backhoe as not intended and its jabbing me in the ribs ;)
It looks to me that the black talon seat would fit your machine (by simply looking at the front hinge bracket).
