Simpson Pressure Washer Oil
7,316
Have a Simpson Pressure Washer with Honda GC 190 engine.
I’ve used the Simpson oil a few times, but the stuff is ridiculous in price. $17 for a pint.
Today saw it’s 15w-40 at TSC.
I started to look for an equivalent a couple years ago, but didn’t know/realize it’s 15w-40.
I’m thinking just plain old diesel-rated 15w-40 should work? I’d probably use a synthetic; just my preference.
MOOTS
MX6000
Jun 27, 2019
2,227
2,823
Canton, Georgia
I have a few cat pumps at work. Been using cat oil in them, bottle says it’s ISO68. So, I’ve been using my bulk 68 in them for over a year now.
7,316
I’m sorry, I don’t know what “cat” pumps or “cat” oil means….
In this machine, the crankcase oil is also the lubricant for the pump, unless I’m missing something terribly.
My apologies for my ignorance. This is new to me, which is why I stuck with the OEM stuff.
Tughill Tom
B3200
Dec 23, 2013
1,458
2,116
Turin, NY
So the crankcase oil from the Honda, also lubes the pressure pump? Or am I missing something?
Cat is a pressure pump manf.
7,104
I dont think so. Crankcase refers to the pump crankcase not the engine crankcase. Where do you add it?
7,316
Tom - far as I know. No oil fill or drain on the pump itself.
7,316
Dan - just one drain and one fill on this machine.
Honestly, I didn’t put a lot of time into the Owners Manual….😀 I have operated a lot of stuff for 50 years, figured I’d be okay…
MOOTS
MX6000
Jun 27, 2019
2,227
2,823
Canton, Georgia
Looks to be a non serviceable pump. Or you could pull pump apart with those Allen bolts dump out the old and put in new. Will be a heavy spring in there, nothing will fly, just might need a clamp to go back together. 53D1B082-6BC1-4A18-83FB-9F1E5B6CC6E0.jpeg
This is a comet pump I did a few weeks ago.
Tughill Tom
B3200
Dec 23, 2013
1,458
2,116
Turin, NY
OK, so you need the ISO # and type of oil, i.e regular non-detergent dino or syn for that pump and go with it. I wouldn't switch from dino to syn or vice a versa, due to seals in the pump may not like the new oil.
7,104
Might be time to read the manual. In my experience pumps simply bolt to the outside of the engine and have a separate drain and fill. Pump drain at 8:00 in the video.
7,316
When I saw the 15w-40 tag today, I wondered if a similar motor oil would work. When you talk ISO, I’m thinking that’s a hydraulic fluid?
Again, this is labeled a “pump crankcase” oil….
7,316
Thanks guys, I’ll do my homework here. I do have the manual and should look further.
I don’t want to sound like I’m arguing when I’m guessing myself.
The washer probably has 50 hours on it….if I’m doing it wrong, at least it’s a testament to the resilience of the equipment….despite my ignorance…..😳
7,104
I downloaded a couple Simpson manuals.Based on them the oil you pictured is a non-detergent pump oil. It is not an engine oil.
For gasoline engine pressure washers most times you get a pressure washer manual specific to the pump/washer components and a separate engine manual specific to the engine make and model.
Its entirely possible there is no way to change the pump oil on your machine.
7,316
Dan, Tom, and Matt -
Thanks guys so much for the help.
I wondered about the type of oil, but it does sound like I can’t swap it for a motor oil.
The 15w-40 tag at TSC today piqued my interest, but it is what it is. I’m okay with using an OEM product when needed.
This is thefirst Honda engine I’ve dealt with. Understand their attraction. Nice engine that runs well and starts easily.
After looking at my pictures again, I think the pressure washer needs a pressure washing…..couldn’t use it last year due to weather when I was off work.
Thanks again guys, greatly appreciated!
crbr
2006 B7800, 2022 BX1880
Jan 8, 2010
34
25
TN
That Honda engine is bullet proof. Take good care of it and it will take good care of you. I have owned the Honda 390 engine with a Cat pump for over 25 years (same setup). Still runs like Forrest Gump.
Here is a good library of manuals. Free for a few validation clicks.
To your question; 15W-40 is fine as a substitute. Page 17 of the manual.
No synthetic.
