Hi all,
Brand new member here with an interesting problem.
I just picked up a late 70s B6100D. It is in okay shape, as good as one can expect.
One thing is has is a FEL that was fabbed up for it by the guy I got it from. It had a few minor issues, mainly hydraulic leaks.
I've run those all down and found another issue. The hydraulics are run from an electrical driven hydraulic pump that has it's lines connected to the battery.
If the battery is charged, I get a half hour of use until the battery is totally drained.
I think either the dynamo is going bad, or the hydraulic pump is pulling way too much power.
Does anyone know what the power produced from the dynamo should be?
This seems a bit of a convoluted system. Has anyone plumbed in a split into the 3pt hitch hydraulics to run a FEL instead of adding another pump?
I have lots to learn, I know
