Picture of your tractor on your trailer
6,873
Here's a few pics of the new trailer that I picked up today. I'll get some with equipment loaded next time.
Fork Holder Pockets (look closely under the rub rail).
Reactions: 7 users
Vlach7
L47 305DT JD500C
Dec 16, 2021
449
322
Frazier Park Ca
What NOT to do, load on a downhill with gravel, cantilevers the backend of the truck up, took me for a 50' unintended ride with no weight in the backend of my dually, stopped by itself, with no casualties. Thank God.
Jsjac
B2650
Feb 13, 2022
239
386
This is our B2650 loaded on the trailer for its ride to the house.
I was looking for a little bigger tractor but got a good deal on this one.
I have used it to clean the driveway a couple of times and the snow blower has save my back already. Not having to spend a couple of hours walking behind the snow blower
Reactions: 7 users
Jsjac
B2650
Feb 13, 2022
239
386
Sounds like you need to block up the back of the trailer to keep it from picking up the back of your truck.
6,171
Glad no harm done. Have seen several situations where that ended in a jackknifed mess.
That’s one thing I do NOT like about my trailer. Doesn’t have the ground brace ramps like dirtydeed’s above, so I have to put jackstands under the back of the trailer to load/unload and block the trailer wheels just in case something gets weird. I don’t trailer a lot. If I did it would be quite irritating.
11,725
11,725
Here's the MX6000 HST that I sold last month on the 22' MidSota trailer heading to a friend's to unload round bales. Great tractor, great trailer and a great 20 year old truck still going strong. I have new hubs arriving Monday to replace the factory ones that are wearing out. I only got 156k miles out of them ... junk!
6,873
Yep. Use wheel chocks on the trailer wheels as well. Trailer may still lift rear of truck, but the chocks will keep it from running away from you.
6,873
Those pallet fork pockets are neat.
Luckily I just asked about the fork carriers when I was placing my order. They don't list them as an option, but will do them for new builds for $300. When I asked them why not, he told me that they are trying to stay away from any "customizations" since that puts them at approx 10 weeks for completion. My trailer was 5 weeks from order to pick up.
drumminj
L4701, Mule 4010
Nov 4, 2021
156
119
TN
Question for folks regarding a trailer purchase and tractors...
I plan to buy a utility trailer regardless, for hauling to the landfill, lumber, loose material, hay, etc. Figured it'd be nice if it could haul the tractor to the dealer if needed, but don't plan to regularly trailer it.
Would it make sense/be valuable to trailer it without the loader? I'm looking at 7k rated 16' tandem axle, and the 4701 will be about 5500lbs with loader and loaded tires, so I'd likely be a few hundred pounds over if I don't account for tongue weight, but would be totally within limits if I drop the loader.
Really not eager to drop another $1k for the 10k rated trailer, and if I weren't ever going to haul the tractor, may drop down to a 14 foot tandem instead.
(yes, my truck can pull it and I'll have brakes on both axles)
11,725
I must admit, I'd like that feature on my MidSota trailer. I bought it used but would have chosen that option if I were ordering a new one. I guess I could add that feature fairly easily.
6,873
Sure could, they welded in some square stock about the length of my forks. But, as you can see in the pic, they cut the holes through the main C channel. If you tacked on something below the frame, I would think it would be just fine as well.
6,873
as I recently found out, I wish that the trailer manufacturer that I just bought from offered a 22 footer in 10K. 16 feet is really short (I have a 7K landscape trailer that is 16 feet). It works if I only have a short attachment on my little B series tractor. I also have to turn the hoe sideways in order to get the ramps/gates closed. A 16 ft trailer doesn't give you much wiggle room in adjusting weight distribution either. You'll be hosed for sure if you ever needed to trailer with a three point implement like a cutter.
Utility (landscape) trailers can be handy, but I'd prefer an equipment trailer. You can always build some sides that will slip into the stake pockets if hauling loose material. You can also side load pallets/lumber on an equipment trailer. Tough to do on a landscape trailer.
maybe take a peek here: https://www.appalachiantrailers.com/
Just my $0.02
drumminj
L4701, Mule 4010
Nov 4, 2021
156
119
TN
Thanks for the input.
Hauling with an implement on the 3pt isn't a use case I care to optimize for, vs all the others...I expect hauling the tractor to be rare, but being an engineer I always want to optimize/find a single solution that works for everything :)
The trailer manufacturer I'm looking at (Lone Wolf) makes an equipment trailer with the same sides/rail as their utility trailer, just beefier axles and frame. So from a function point of view it'd be the same, just beefed up in all ways. But the utility/7k trailer would work for my common usage. I've not priced it, but I assume I can upgrade to 5k axles on that without upgrading everything else (frame, coupler, etc) for less, but I'm not sure it'd make sense to upgrade the axles without the frame being beefed up to support more weight.
Anyway, mostly curious to hear if folks think there's a scenario where hauling the tractor with a 7k 16' trailer (likely without loader) would be useful. If not, I'll stop trying to think of the lighter trailer as a possible tractor-hauler, and either go for a utility trailer for utility trailer things, or the equipment trailer (for more $$$) to handle all the scenarios I can see caring about.
Also, feel free to tell me this isn't the place to ask/I should start a thread. This just seemed a good place to try to jump in!
motionclone
May 4, 2018
1,399
996
Maine
Not a tractor but its got a Kubota engine
6,171
Since you mentioned not actually having the tractor yet, thought a few pics of a L4701 on a 16’ trailer might be helpful. By the time you load the rear tires or add wheel weights, loader, implement, etc. you’re on point with tractor weight. I’ve never trailered it without the loader, but I think it’s pretty obvious it would fit with loader and rear implement removed. It’s REALLY tight with loader and just a box scrape. Chipper and grapple, it’s really too short. I don’t trailer much, it pulls great, and have $750 in getting mine roadworthy so no complaints. It has two 7K each axles so weight isn’t an issue.
I have heard some indicate a “16’ trailer” doesn’t have a 16’ deck as it’s measured from some odd point to some other odd point that sounded like it was determined by marketing rather than engineering. My trailer’s deck is 16’ long.
lynnmor
B2601-1
May 3, 2021
1,766
1,574
Red Lion
I will never buy another trailer with 3500lb axles. The inner wheel bearings have zero shoulder to seat against when you consider the large radius on the bearing. The 2-3/8” axle tubes are pathetic and the electric brakes are marginal. After going to the expense of upgrading the axles, I won’t be doing that again. Bent axles, brake drum replacements and wasted Chinese bearings are history for me.
5,188
10K ONLY!
Bigger brakes/bigger tires/heavier axles, stronger overall construction.
You will ALWAYS find new ways to overload a 7K trailer with a 5.5K tractor!
I am an engineer too (Civil).
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
I tow a lot and all I can say is once you go tilt-deck you will never go back. No more ramps!
At times I wish the 22ft was a 24ft.
Reactions: 7 users
