Thanks i guess that will not be any good to me grasping at straws here but it looks like it will become a 2 wheel drive tractorTwo quite different tractors from the 1970's. Front wheel drive was an after-thought on the L225. The differential was off-center, with a driveshaft coming from a side gearbox on the transmission. The axles had u-joints.
The L245DT got a completely redesigned system - with centered differential and driveshaft. The kingpin drive feature was added (giving better ground clearance and tighter turns) .
For a time around 1976 both models were produced - but the L245DT general design idea became the standard.
View attachment 68572 View attachment 68573 View attachment 68574
Your other post indicated you needed a "crown wheel and pinion".Would the 245 dt and the 225dt be compairable front drive could i swap them
HI Dan i called messicks last week was my first port of call they told me nothing was available i will call them again today would you have a part number for that MikeYour other post indicated you needed a "crown wheel and pinion".
Messicks shows L225DT bevel gear assembly available for $699.
Serial number break on the L245DT but both are available - one is $833 and the other $612
Called messicks this morning yes its on website but it is not available has been out of production for a little time now no stock left in north America MikeHI Dan i called messicks last week was my first port of call they told me nothing was available i will call them again today would you have a part number for that Mike
Well I triedCalled messicks this morning yes its on website but it is not available has been out of production for a little time now no stock left in north America Mike
thats a permanant situation no more will be madeWell I triedIs this a permanent situation or could they not say?
Mike - look above at my post suggesting you contact 007kubotaguy.thats a permanant situation no more will be made
Thanks for the prod i tried to contact him at 8 30 this morning but think i only messaged myself tried again if i get no reply i think i will need a it of help to contact the guy Thanks MikeMike - look above at my post suggesting you contact 007kubotaguy.
Notice he gave ato my post …..I’m thinking he might be able to help you out….worth a shot.
Good luck.
I got hold of 007 kubota guy no luck there eiThanks for the prod i tried to contact him at 8 30 this morning but think i only messaged myself tried again if i get no reply i think i will need a it of help to contact the guy Thanks Mike
I got contact with 007 kubota guy he only has a 2 wheel version so no luck there got to just keep on looking thanks MikeMike - look above at my post suggesting you contact 007kubotaguy.
Good luck.
Oh, too bad. It was worth a shot. Lance is a good guy. Helped a bunch of OTT guys when he can.I got hold of 007 kubota guy no luck there ei
I agree completely! I've met Lance on a few occasions. Even bought a loader for a L245DT from him. A great guy!Try Lance - 007kubotaguy he has some older L parts. He's helped quite a few here out.
Send him a message.
