found a kubota 245 Dt
rbargeron
Jul 6, 2015
1,174
242
western ma
Two quite different tractors from the 1970's. Front wheel drive was an after-thought on the L225. The differential was off-center, with a driveshaft coming from a side gearbox on the transmission. The axles had u-joints.
The L245DT got a completely redesigned system - with centered differential and driveshaft. The kingpin drive feature was added (giving better ground clearance and tighter turns) .
For a time around 1976 both models were produced - but the L245DT general design idea became the standard.
mike.l
L225 DT
Oct 27, 2021
10
tillsonburg
View attachment 68572 View attachment 68573 View attachment 68574
Thanks i guess that will not be any good to me grasping at straws here but it looks like it will become a 2 wheel drive tractor
4,711
Would the 245 dt and the 225dt be compairable front drive could i swap them
Your other post indicated you needed a "crown wheel and pinion".
Messicks shows L225DT bevel gear assembly available for $699.
Serial number break on the L245DT but both are available - one is $833 and the other $612
rbargeron
Jul 6, 2015
1,174
242
western ma
Back in 2015 I worked on a L225DT front drive - it had a chewed gear and bearing in the side gearbox link here. I got a lot of good help on this forum and even found some good used parts. Maybe what you need is out there somewhere - good luck - Dick B
5,764
Try Lance - 007kubotaguy he has some older L parts. He's helped quite a few here out.
Send him a message.
mike.l
L225 DT
Oct 27, 2021
10
tillsonburg
HI Dan i called messicks last week was my first port of call they told me nothing was available i will call them again today would you have a part number for that Mike
mike.l
L225 DT
Oct 27, 2021
10
tillsonburg
Called messicks this morning yes its on website but it is not available has been out of production for a little time now no stock left in north America Mike
5,764
thats a permanant situation no more will be made
Mike - look above at my post suggesting you contact 007kubotaguy.
Notice he gave a 👍 to my post …..I’m thinking he might be able to help you out….worth a shot.
Good luck.
mike.l
L225 DT
Oct 27, 2021
10
tillsonburg
Good luck.
Thanks for the prod i tried to contact him at 8 30 this morning but think i only messaged myself tried again if i get no reply i think i will need a it of help to contact the guy Thanks Mike
mike.l
L225 DT
Oct 27, 2021
10
tillsonburg
I got hold of 007 kubota guy no luck there ei
Good luck.
I got contact with 007 kubota guy he only has a 2 wheel version so no luck there got to just keep on looking thanks Mike
5,764
Oh, too bad. It was worth a shot. Lance is a good guy. Helped a bunch of OTT guys when he can.
