pokey1416
Jun 24, 2020
567
843
SW Michigan
Used the new EA disc harrow to turn over the weeds.
D
Deleted member 47704
Guest
Ripped out another tree about 4". When I got the tractor some thought it was too big, it could be bigger for some off these trees.
3,445
2,025
Ordered 5 mo' hoses. BIL was going to use Katy to haul a limb that broke on the edge of their yard. But one of the curl hoses was dripping, so he put her back up. I've replaced most of the hoe hoses and it looks like she wants loader hoses too.
5,791
ah you have a backhoe! Are these holes used for the backhoe? I was wondering what they may be for, or possibly for shipping?
Yep. BH subframe mounts there.
5,791
Very nice. Thanks for the info man. I have A rear backhoe on mine now, so i need To figure out a good spot to tie it down with the hoe on it. As for the front i was Thinking about doing the same as you, but with a shackle Mount
You can use a clevis on the draw bar with the hoe mounted (it does not interfere). I do it all the time when chaining it down on the trailer. It fits in the kubota toolbox that comes with the tractor. Just remove it if you have a 3pt hitch implement attached. I found out the hard way that the clevis can interfere with the lower link.
Magicman
Oct 8, 2019
6,023
9,393
Brookhaven, MS
knotholesawmill.com
I cleared up which should be the last of the Hurricane Ida deadfalls and then
Helped a Grandson plant his deer food plots.
All of my bushhogging and planting is done, but I will have to top dress the food plots with Nitrogen around the first of December.
RichardAaronlx2610
Aug 3, 2021
451
506
New Jersey
That’s what I’ve done the last few times, i pull The drawbar out and put a shackle through the second hole in. What toolbox? For the rops models? I want To build a toolbox for mine
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,499
3,619
PEI Canada
Borrowed a friend's post hole digger to dig a few holes.
It is pretty light compared to what I used back when I worked on a farm. I had to use a bar to keep pressure on the auger to dig. Still better than digging by hand.
Crash277
BX23S
Jan 17, 2021
844
621
Been a few weeks since I posted. Slaughtered our pigs yesterday. The plan was to hang them from the IH454 and use the bota for the guts. I dug a 6’ deep pit. But the IH blew a tire on a long weekend after lunch on a Saturday. So. The little BX did all the work.
Reactions: 7 users
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,502
521
Went for another trail ride with the wife in the RTV. Got a bit of rain. 101_5549.JPG 20211010_111015.jpg 101_5560.JPG
Reactions: 10 users
PortTackFarm
L3560 LE (ROP's) w/ LA805 FEL, LP RCF 2072, BB2572 and WoodMaxx WM-8H
Jul 2, 2021
147
179
The Ville and The Farm (KY)
S-G-R
Jun 17, 2020
1,499
3,619
PEI Canada
Waiting for the buffet.
S-G-R
Jun 17, 2020
1,499
3,619
PEI Canada
Put another skim of gravel down. Got a concrete pad coming later in the week. The LX2610 is the best shovel/wheelbarrow that I have ever owned😄
billydee
B2150HST
Oct 11, 2021
Durango, CO
Tried to figure out if I need a new battery or not.
Have the B2150HST and had to jump start it yesterday after it sitting unused most of the summer then let it run for about 30 minutes or so. Started up ok an hour later.
Today I cleaned up the battery terminals and connectors and it "almost" but not quite started. Jumped it again today and let it run nearly 60 minutes.
Started a search for a replacement battery which feels most likely at this point. The current battery is a Deka 524FMF.
BTW, this is my first post here....
Rzims
B7800
Apr 28, 2021
20
California
Earlier this year, I bought a B7800 and used it all summer. Most recently laying a patio. (my wife loves driving the tractor)
On the weekends when I wasn't using it, I've been cleaning it up. The previous owner let it sit outside on the coast for years and it had quite a bit of rust. Lots of wire wheel, primer and paint....and it almost looks like new..
D
Guest
Greased the loader. Love that DeWalt cordless greaser.
My Land Pride RB1572 rear blade got delivered today. Not the one I wanted but was told the RB1672 wouldn't be available until next year.:mad:
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
Murphy was around here today.
Spent the morning searching for, finding and repairing the leak from the fuel tank which I posted about in service and repair.
Got the M fired up and went back to the hemlock stand to haul the logs that I left after discovering the aforementioned leak.
Moved the logs and noticed one of my rear tires is leaking rimguard, looks like it is from the valve stem:(
Ok, we will deal with that later so I went to fell another hemlock and ...no start with the Jonsered.
Does not seem to be getting fuel. It had been running fine earlier.
That did it, I ran down to the local saw shop and bought myself a brandy new Husky 562XP:)
A good way to end a not so good day.
