random
Nov 2, 2020
716
401
NC
Today I tilled my garden field of weeds, the part that isn't still producing. Getting ready for fall cover.
Before
After
Reactions: 6 users
D
Deleted member 47704
Guest
Installed cruise control and tilt wheel on my LX2610 SU. Now I have the worlds only SU with tilt wheel. Did the cruise control because I had it apart.
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
Been busy in the woods, finally took the camera with me and got some pics.
Already shipped one truckload and this lot makes two, at least one more load still standing.
This tree is typical of the mature hemlocks and the underbrush in the fall zones is dense!
Reactions: 11 users
UpNorthMI
May 12, 2020
849
567
Up North, MI
I changed out my front third function hydraulic couplers today on the FEL of my L3901, the original 1/2” ag style couplers have been leaking since I started using my grapple earlier this year. My dealer fitted 2 male ag couplers to the tractor when new, I fitted the 2 female ag couplers to the grapple. Not sure why I could not get them to not leak.
I have rear ag connectors on all of my tractors and have no issues.
I had 2 existing pairs of 1/2” flat face couplers that I had removed from other items so I fitted those using a male and female on the FEL and the other pair on the grapple, problem solved, no more leaking. All the leaking ag connectors went in the trash, I must top off the hydraulic fluid as I have been leaking for months.
just one of those jobs you keep meaning to do is finally done.
I have ag fittings on my MX5800 FEL, never had a leak, I’m thinking that maybe I purchased some slightly different female ag style couplers that were somehow not compatible with my FEL fittings on the L3901. Not going to dwell but may just swap my MX5800 FEL fittings out to flat face along with the heavy duty large grapple fittings, everything for my track loader and excavator already use flat face couplers. Will keep using ag fittings on the tractor rear remotes.
Newaterman
LX2610 HSDC, Z422-54KW
Feb 14, 2021
99
274
53
Vermont
Dropped two more trees as part of my effort to give some apple trees room to breath, and our Adirondack chairs a view of the mountain. The couple other ones I’ve dropped are in the brush and I’ll get them later. Only good place to drop both of these was onto a grassy open area. Came through with the tractor to clean them up.
Reactions: 8 users
7,115
Mowed the lawn yet again.
Been an ongoing thing…very wet year. Also mowed/chopped leaves up under the ‘Moline.
My crew:
FreezinGator
BX1500 LA181 FEL 48MMM Back blade
Jul 10, 2020
58
Upstate NY
Its leaf season in upstate NY. Got out the lawn sweeper early this year - I am going to try to maintain it and not wait they are deep - I have 4 huge maples in the front yard. Once your get the rope pull to dump and reset you can do the whole job from the seat of the tractor. I use the blower to clear the driveway and around the trees while the tractor warms up and then it is almost like cheating. I dump them in the back yard along the woods line and push it back with the loader when I need to. Sure beats raking! :cool:
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
Was a good day to work with the grapple. I have two goals with it. One is to harvest some New England Potatoes and use them for landscape features (that the Mrs approves of, of course). The other is to clean out part of the fenced in acre in the woods for the dogs. There are several downed trees in there and large rocks that make it difficult to move around.
First get the back blade off & ballast box on - need the maneuverability.
I couldn't lift this tree whole so I just got one end up at first to cut off a chunk.
Then I carried both pieces and dumped them over the fence. A slow move with all this weight so high!
Then I got to move some rocks
It was a good day
RichardAaronlx2610
Aug 3, 2021
451
507
New Jersey
So the dealer said my Front End Loader, grapple, third function, and forks are finally in, so i dropped It off to get done on Wednesday. When i was There he said that he thinks a subframe kit came in for my
Backhoe, i guess We will see!
UpNorthMI
May 12, 2020
849
567
Up North, MI
It was a great weekend here in Michigan, cooler temps and dry. It was time for a final day of wood splitting before hunting season and the eventual arrival of winter.
We grapple loaded the tilt trailer with large rounds from the storage pile, transported them back to the main barn area and tried to set up where wood handling would be at a minimum. Filled the pick up and a trailer for down state home use then made a large stack for outdoor use during hunting season.
Those 18" long 30" diameter rounds are definitely getting heavier every year, not sure what I would do without the hydraulic log lift on the splitter. Most of what we were splitting was more in the 20" - 24" diameter. Grapple loading to the trailer may be a little slower than by hand but it is a lot less wear and tear on the back! It would seem an impossible task if it were not for a buddy and a couple of tractors to help out.
The All Wood - Oak model commercial log splitter with adjustable 4 way wedge & log lift did a full day of productive work.
A great day out in the woods. Then you get up the next day and remember you still have to unload the truck and trailer full of wood!
Reactions: 6 users
6,161
Water service install in town today. No issues, all went smoothly. Limited damage to tree roots (client was worried about the trees). The guys did a great job cleaning up after the dig (must be the "landscaper" in me). I just can't leave a job looking like a mess. Client came out to take pics and said "wow, it's like you guys weren't even here". I'll take that any day. She was happy to have water turned back on after a week without it...you know, it's the little things...:)
anyway, here's a few pics. If you guys think it's too many pics, I'll be more selective in future posts...
Here we go
I snapped a pic of client taking a pic of us..
Cleaned up...smashed all the dirt into the trench to compact it. No dirt left behind or hauled away.
This one was a "coerced" pose...you know, for the "management" team...;)
Reactions: 12 users
Toyman
B7100HST, 1630, 4' Tiller, 4' Brush Hog; Mahindra 5005/Loader, Woods Cadet 84,
Apr 15, 2019
120
104
Pittsburgh
Finished up mowing the last food plot before hunting season. Turnips already started to germinate in the new plot. Pics of the early plot planted 2 weeks ago and a pic of the clover plot I put in two years ago. The deer are happy and their bellys are full :)
Reactions: 7 users
5,185
Here we go
VERY nice job!
Newaterman
Feb 14, 2021
99
274
53
Vermont
From yesterday, I mowed with the zero turn and moved my new smoker to the shed from my car with the tractor. The isotune over ear headphones we got for my wife and I have been pretty excellent on the mower. Even inspired me to order the ear bud style for work. Back to the boat now for a week and change of cleaning the windows and topping off the oil.
Reactions: 6 users
5,161
I know That a lot of stuff is all made in the same factories, but I’ve never had much luck with anything less than a factory battery in anything.
My original Kubota battery lasted 12 years, and it was an Eastern Penn. In my new Ford the battery lasted 6 months, and then crapped out. It was replaced with a new "factory" battery, and that one lasted about 2 1/2 years. My wife has the same car like mine, we bought them a month apart, and hers lasted 4 years. You never know how long a battery is going to last, even when they both start off equal. Her car moves every day, and mine can sit for a week at a time, and the battery gets no exercise.
5,185
View attachment 66472 View attachment 66473 View attachment 66474 View attachment 66475 View attachment 66476 View attachment 66477
Is the tug yours for work use, or just for pleasure?
bird dogger
Vendor Member
Feb 24, 2019
1,740
1,712
North Dakota
I found a nice used BX2230 for sale and convinced a brother he needed it. One of the attachments was the front mount snowblower with a hand crank for chute rotation. I had helped a neighbor convert his to 12vdc rotation and decided to make a “Christmas Gift Kit” for the brother’s rig.
A short piece of angle iron bolts to the blower near the chute. A slot cut with a cut off wheel provides an easy way to secure the 12vdc window regulator motor to that bracket with hose clamps. A small piece of black neoprene rubber between the bracket and motor provides a little cushion and "give" during operation.
A short piece of round rod turned and bored to the proper OD & ID matches the motor shaft to the hand crank receptor/mount. Set screws secure it to the motor shaft.
Here it is mounted in place. I’ll clean up some sharp corners and paint the bracket Kubota orange. The motor spins the chute like nobody’s business!
I’ll let him decide where he’d like a control switch to be mounted. It's a pretty easy and cheap way to add motorized chute rotation to these snow blowers.
Reactions: 6 users
