Front & Rear 3rd Function?
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
I need another line of fluid for a grapple on the front ( which I plan to use regularly ) and I need a line to the rear for small seed drill ( which I'll rent from the NRCS and use rarely ).
Would it be crazy to add a 3rd function kit ( i'm thinking the Summit Kit ) for the grapple and then, for the occasional rear hydraulic needs, run temporarily hoses from the font to the rear? Once I'm done with the seeder, I'll remove the hoses and go back to just a regular 3rd function to the front.
Any better solutions? I suppose I could put a diverter valve in somewhere but that seems like a lot of cost / plumbing for something i'll only a handful of times ever.
I'm not sure what the cost of the hoses / fittings would be? Just brainstorming for now.
I have a L3130 btw.
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
That is exactly what I did. I already had the 3rd function on my tractor and no rear remotes. I bought two lines and made a mount for my roll bar and attached a breakaway clamp with breakaway couplers. I can easily remove the lines by removing the two bolts on the back. There are many solutions to adding hydraulics, but I went as simple as possible.
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
That is exactly what I did. I already had the 3rd function on my tractor and no rear remotes. I bought two lines and made a mount for my roll bar and attached a breakaway clamp with breakaway couplers. I can easily remove the lines by removing the two bolts on the back. There are many solutions to adding hydraulics, but I went as simple as possible. View attachment 64869 View attachment 64870
That’s awesome. Just what I envisioned.
random
Nov 2, 2020
716
401
NC
I keep reading about "third function" - what exactly is it? From what I read it's just an extra valve & cylinder on the front end, purpose of which can vary?
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
That's pretty much it. Function one lifts / lowers the forks, function two curls / uncurls the bucket. Anything else ( like a grapple arm ) needs another circuit or “ function “….. a third function.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,537
central ct
I went the other direction. I have 3 rear remotes. For my grapple (coming some day) I will have a pair of hoses from the rear to next to the loader valve. There I have a pair of couplers in case I ever want to remove the loader. From there I have a pair of hoses to the loader where I made a bracket for the grapple couplers.
I just have to finish running the rear pair.
Some pix:
at the loader valve - I'll come out with a long sweep 90 towards the front and then follow my rear remote hoses to the back (about 8' of hose length)
The front - I attached strut to that shield plate
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
Thanks CRFJR. The strut you attached to the shield plate? Where did you get that? Did it come with an install kit? I'd like to have one.
LB
ctfjr
L3800HST
Dec 7, 2009
1,982
2,537
central ct
LB
It's a piece of standard low strut. The company I works for sells 20 footers. I'm always looking for damaged (bent) pieces they are going to scrap. I just cut it to size and rattle can painted it Kubota orange. On the other side I similarly mounted a 12v 20amp waterproof socket for my sprayer.
Crash277
BX23S
Jan 17, 2021
844
621
I have the 3rd function for my grapple, with lines plumbed to the rops. Using the grapple in the winter is extremely Unlikely so it’s set up for my chute on my rear blower. With the plan to eventually get a hydraulic top link. Works great. Next up will be an electric actuator for the deflector on the blower that will also run a winch. Second picture. The disconnects go to the loader so I can remove it. The rear lines are hard lined as they will never require removal.
*edit. These are old pictures. I didn’t realize I don’t have a pic of it with the loader disconnects. But they are on the top ports of the valve.
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
So, you split the line after the 3rd function valve, run a set up front for the grapple and a set to the rear for whatever. All the hoses stay in place no matter which end you're operating. Correct?
Very good idea.
Crash277
BX23S
Jan 17, 2021
844
621
Very good idea.
yup! I do have couplers now on the lines to the loader. I will take a couple pics in a bit.
Crash277
BX23S
Jan 17, 2021
844
621
Very good idea.
here are some better picture. The lines to the front stay with the loader when I disconnect it. I made that bracket for the front couplers.
Chanceywd
Mar 26, 2021
718
665
central ny
Some pix:
I like your install but noticed the retainer pin for the loader mount. Isn't it supposed to be in the small hole so it hangs down? In that position it is in it can move and the large mounting pin can work out.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,537
central ct
Good pickup! I've had this tractor for 1 year now and never noticed that :( - fixed ty
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
Love it. This will be my plan. I'll try to source all the parts from Summit tomorrow.
I'm trying to figure out your fittings bracket on the ROPS. Did you custom make it or can you point me in the right direction to obtain a way to affix the hose fittings?
ctfjr
L3800HST
Dec 7, 2009
1,982
2,537
central ct
Don't know if you are directing that to me LarryBud but just do a google search on "hydraulic coupler bracket". You will get all you ever need :)
uh oh - just saw you said ROPS :(
I got mine with FitRite Hydraulic's rear remote kit.
BobInSD
L5740
Jun 23, 2020
373
128
South Dakota
Some pix:
This is what I have. I haven't tried to actually run anything up front with it. There will probably be coordination issues since the remote lever and the loader joystick are both on the right-hand side of the tractor (and I only have one right hand)
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
Thanks. I'll look it up.
Crash277
BX23S
Jan 17, 2021
844
621
not sure about your model. (i can post a pic later)... on my 23s the dealer drilled 2 holes into the taillight bracket and put the fittings there. works great
