Picture of your tractor on your trailer
lynnmor
B2601-1
May 3, 2021
1,721
1,523
Red Lion
Getting ready to tow the tractor
wrong tow vehicle or trailer or both?? Getting ready to tow tractor first time and was told by a hauler the Sierra 1500 (‘14 w/ 6.2L eng, tow pkg, 3.73 ratio) wasn’t up to the job! By my calculations the tractor plus implements is 4500#, trailer is 3300# or 7800# gross weight. Truck says it’s capable of 9000# gross tow weight (w weight distributing hitch) and 15k combined … guy says it’ll run like a dog up the hills and won’t be in the sweet spot of the torque curve w the 3.73. Is this all true and I should be looking for a lighter aluminum trailer (I don’t want to be buying a new truck in this market) ? Thinking of loading it up and testing, if I can get the tongue weight right.
7800 is a lot for a 1500 but it will do it. You are looking at the power, but of more concern is the suspension, brakes and handling.
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
Look at the sticker on the side of the drivers door. It will tell you how much weight you can have total for your truck. This weight will include passengers, fuel, any accessories plus tongue weight.
Take that weight and subtract passenger weights fuel any accessories and that will be the allowable tongue weight.
For tongue weight add the distribution hitch weight also.
I know I pulled a 9K enclosed trailer with my F150 Eco boost with out an issue. If the truck you are using is rated to pull it, I would give it a shot, if not then time to rethink it. Remember it is easy to get things moving, but stopping is another issue.
6,421
Too much truck? Or too little trailer? Or, both?
I think the real issue is that the hitch is just too high on the truck.
If anyone has a line on an aluminum 20 footer 9990K in my area, let me know. I want need one. ;)
JimsF
Kubota LX2610, LA535 FEL, BH77 Backhoe, 20’ Utility trailer
Sep 15, 2020
30
NH
Thanks for the info … think I’ve got brakes taken care of with electric on one trailer axle. tongue weight I can adjust with tractor load positioning to get 8-10% on the hitch and 10 plys should stiffen the back end for handling. The rig meets all the truck weight specs, except they spec a weight distributing hitch over 7k trailer weight. I’m thinking I can get away without it by minimizing truck payload to just me.
lynnmor
B2601-1
May 3, 2021
1,721
1,523
Red Lion
In Pennsylvania a trailer will not pass inspection if there is no brakes on one axle. 10% should be considered the absolute minimum for tongue weight, I would like at least 12%. If you ever experienced a sway issue from too little tongue weight, you will never do it again. A WDH can be bought at Harbor Freight for $210 and they work fine.
10,382
How are you able to determine if you have 10% compared to 12%?
lynnmor
B2601-1
May 3, 2021
1,721
1,523
Red Lion
I know the weight of the trailer and the tractor weight giving me the total. I then use my scale and move the load to get 12.5% of the total. A cheaper way is to use a bathroom scale and some materials to create your own. homemade Quarries, feed mills, landfills and truck stops have scales if you want to do it that way.
10,382
Cool. Thanks for the links, particularly for the link to the Sherline scale ... I can see one of those in my immediate future.
B737
LX3310
Jun 9, 2019
2,022
2,205
They make scales you can use while lifting the trailer tongue with to check this. They are usually accurate within a few percent.
JimsF
Sep 15, 2020
30
NH
I thought with tandems you should use less tongue weight .. 8-10% ?
SAR Tracker
Nov 17, 2020
252
375
Central Oregon
Some of the over 100 cords of wood that will be donated to folks in the area this fall. The LX2610 sure helps with the heavier chunks of unsplit wood.
Reactions: 7 users
5,593
Grand L6060 and 24ft tilt
Sweet rig!
Never tried the wheel strap method. Still running 3/8” Grade 43 chains through shackle on drawbar on back and loader tube on front. Do you find the wheel strap method easier and/or better than chains and load binders?
Also, it looks like you’re using auto type straps on the fronts so that’s pretty straightforward.
What you doing for the rear? Looks like a standard strap that you’ve woven/wrapped around the wheel somehow. Have you found that to be reliable to not slip?
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
577
582
Lake Almanor, Ca
I used this one to set my rig up…works great. I figured out the ideal set up for my trailers…much safer way to tow.
