Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
Keep moving is the answer. I have 30 years in medicine and when you stop you’re done. On that note I took my shiny new L2501 out today to help me put in posts for a gate on our pasture. Two 8 ft x 8in pilling s are HEAVY but my forks made transporting them to the site a breeze. Oh and it hauled the 160lbs of concrete as well. Love m some Kubota today.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
Last evening I drilled the 10 holes for the light posts and planted the 4X4's. Since my driveway in that area was all 'fill' there is a load of lumpy stuff in there. Fortunately I only had to move one of the holes because I couldn't get through the rocks.
The phd did the hard work, all I had to do was clean out the holes with a manual phd and shovel the backfill. The 4X4's are in about 30" and now I have to start mounting the lights and running the wires.
It only took about an hour start to finish but I had to wring out my shirt because of the temps / humidity.
Reactions: 9 users
7,007
this power mole thing sounds wild! what does it do and how does it work?
Trenchless boring and pipe bursting machine. We use it to install new water lines and waste line replacement. It pulls a cutting mole with new pipe attached to a very heavy cable thru the old pipe (cast iron, PVC, Terra cotta etc). The mole splits the old pipe as it is pulled thru making way for the new pipe. The new pipe is also attached to the mole, so its pulled thru the old pipe at the same time.
It works pretty well when you can get access to both ends of the system and need to go under objects (porches, driveways, roots and utilities).
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,735
4,565
PEI Canada
Got this piece today after a 2.5 month snails pace through the postal services. Glad it's finally here and looking forward to installing it.
S-G-R
Jun 17, 2020
1,735
4,565
PEI Canada
Bam! Easy installation and great fit and finish.
And got my hydraulic top link on. Need to change the straight fitting out for a 90° elbow.
Ikc1990
Kubota m125x, m9000, cat 226 skidsteer and other equiptment
Dec 2, 2020
294
131
Vermont
Well I cleaned chicken coop, moved water tubs swapped dirty out of pastures for clean ones and pressure washed. and fixed 3pt hitch
fruitcakesa
M4 071
Oct 26, 2010
892
308
Cavendish Vermont
Been cutting firewood in the back 40 and skidding the logs to my wood pile.
The Norse 450 winch is a beast and makes the job a pleasure; no more dragging chains and cables to reach those distant trees:p
shootem604
Apr 23, 2018
874
British Columbia
Found what I thought was another septic tank on the yard. Turns out it is just connected to my shop's floor drains. It is an old fuel oil tank (one of those 2'x6'x4' steel tanks) that was about a foot under my driveway. Surprisingly it hadn't collapsed with all the heavy equipment I've had coming and going. Dug around it with the backhoe and cleaned up with the shovel. Going to pour a slab of concrete overtop with some cleanouts poured in.
Old_Paint
Dec 5, 2020
2,051
2,343
AL
I walked past mine, looked at it stuffed into the corner of the garage sitting on its battery tender. Haven’t used it since the beginning of April, screwed up my shoulder and needed surgery. Surgery was 6 weeks ago so I gave it a pat on the fender to let it know I haven’t forgotten about er. :)
Been there, done that. Right shoulder, complete rupture, repaired in June last year. Left shoulder, arthritis, and spurs, and a small tear, repaired in October last year. If you had a cuff repaired, count on a 10 month healing process. Do EVERYTHING the doc and therapists tell you to. Some of the seemingly redundant exercises are very necessary to restore range of motion. Strength takes a long time to get back, and that ain’t gonna happen if you don’t have full range mobility back. The last surgery on my right shoulder was the second rupture. First time was in 2013. I’d just really gotten back to full strength and then fell on my front porch in 2018 and ripped it again. If I tear it again I’ll have to have a complete reconstruction which is longer healing time than a cuff surgery. I’ll probably become homicidal by the time that’s done. Gotta love the Immobilizer 2000. Get a wrist brace if you have to wear the sling at night. You’ll thank me later.
Old_Paint
Dec 5, 2020
2,051
2,343
AL
Wasn’t on or to the tractor, but was definitely FOR the tractor. More shed work.
However, I did dig the pad for the ramps with the undersized BB yesterday.
Newaterman
LX2610 HSDC, Z422-54KW
Feb 14, 2021
99
275
53
Vermont
5C0A2969-4B86-49A1-A00F-E6AEC68604D0.jpeg E6D424A0-E1EB-4FE4-A6A3-D4854F75AA8E.jpeg
Second day back from the boat, took the 422 out to cut our 3 acres of grass.
redfalcon302
L3800, LA524 SSQA loader, RCF2060 rotary cutter, EA Land Shark Plane, Box Blade
Oct 22, 2020
Knoxville, TN
Working the EA Wicked 55 grapple pretty hard all day.
Lost a loader pin bolt so I improvised with a few zip ties. Going to the hardware store to get some bolts or pins. C2F1DAD9-C0E9-4ABB-889D-2F0DBDEA8BD5_1_105_c.jpeg
This grapple is a game changer for burning brush piles!! Love it. Would buy it over and over again. 0 regrets.
Reactions: 7 users
Newaterman
Feb 14, 2021
99
275
53
Vermont
Ohhh....422, that is exactly 1 better than my 421 :) (and it looks like it's all in that super comfortable looking seat)
the seat and transmissions are the primary reason I splurged for this over the 200 series they had at the dealer. Zero regrets, great machine. Especially with my bumpy yard!
Crash277
BX23S
Jan 17, 2021
844
623
Working on my driveway expansion and the front right is flat again. I think I’m done with these R4s on the front.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
I feel your pain :(
I have been really lucky and only had one flat on all the tractors I've had. Came up against a rock in the woods and didn't realize it until I popped the bead on the rear. No matter what I tried I couldn't get it to seal. 1-800-call-tireguy
If nothing else came from it, now I am even more careful
Crash277
BX23S
Jan 17, 2021
844
623
New cable trenching attachment. I’m going to bury over 1000’ of dog fence. Figured. Why dig by hand...
JoeBabbs
L3800, FEL, BH, box blade, front tine bucket, hydraulic front angle blade
Jan 20, 2020
26
Ithaca, NY USA
Might not be the correct place, but tried out my new Box blade on the driveway of our vacation getaway to try and smooth out one rough area. Definitely made it worse, too many big rocks. Driveway is 1/4 mile easy with 100 ft bad spot from washout.
Box blade and tractor worked great. Broke one of the four scarifier blades in half after first hour.lol
Have to give a shout out to Messicks. I ordered a new scarifier yesterday morning and it hit my front porch at 0945 this morning. Very impressive. There is a dealer I go to about 40 minutes each way but I will not be up there for a week.
With fuel prices $14 shipping is nothing.
Cheers J
You may need more gravel over the big rocks. Unless you want to dig them out.
