9,247
Planted 7 green fields anywhere from 1/2 acre to 1 1/2. 11 1/2 hours worth.
How do you plant a green field?
All of them that I plant are brown... unless you over seeding... then I guess they are green. :D
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Had the loader off today,figured it was a good time to put the kids to work
Holleyman
Kubota B6001, Caterpillar 252B, AM General M813A1, Ford 8N, Komatsu PC30
Sep 25, 2013
70
80 acres in Athabasca AB
Finally finished the last of the leaks. The front differential pinion seal and the front PTO shaft external seal. I managed to replace the transmission shaft seal without splitting the tractor and only had to build one special tool.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Family time, very nice!
Those two love the tractor,well just love being outside,but love riding/driving everything,my boy was upset I didn’t get the pressure washer out to clean it,they love power equipment,I let them use everything they can
3,168
A few days ago, I unloaded my B670 parts hoe from the trailer & stashed it in the back of the garage. It was everything my little B219 FEL could handle-if it had been 3 lbs heavier, I'd have been screwed.
markbxr400
L3901, LA525, RC1860, SCR0660, BB1260
May 19, 2018
56
Magnolia Springs, aL
Yesterday, while 10 minutes into simply moving small logs from a pile to my burn pile, I blew a hydraulic hose on the FEL of my 17 L3901.
Went to my local dealer today to try to buy another one. None in stock. But he did tell me simply to go to an auto parts place about a block from my house, where he knows the owner, and knows he makes hoses for all the local farmers.
He made up a replacement while I waited. Back in business!
shootem604
Apr 23, 2018
874
British Columbia
Since the fire ban has been lifted and my burn pile has dried out, I had a massive bonfire and did some yard cleanup with my L245dt. Then cleaned up some garbage along the road, dumped by inconsiderate backcountry users.
L35
Jun 13, 2010
611
595
CT
Ran 20 similar sized loads out to the curb, for bulk storm pickup today, about 2 hours worth of work. All pine 3 75’ trees we lost during a storm back in the spring.
markbxr400
May 19, 2018
56
After replacing the ruptured FEL hydraulic hose, finished loading and igniting the burn pile, then dug a trench and moved a large rock (relative for my area that has zero rocks), and put together a new trials obstacle. Having the capability to build my play area is awesome.
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
Moved a fridge one mile.
