shootem604
Apr 23, 2018
874
British Columbia
Yep, get the kids hook on fun work! When they get older they will have skills, a work ethic, and no trouble finding work. They'll also be addicted to tractors and won't be able to afford the other vices!
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
Mowed the lawn then split some fire wood. Used the loader to move it.
I then did a small mod adding a pistol holster in the cab. Necessary? Probably not. But who knows?
shootem604
Apr 23, 2018
874
British Columbia
It has been a good year for berries around here, so the bears have been around and in the yard. I have a .45 or a 12ga handy - just in case the kids or dogs have a run in with Yogi.
tiktock
225
Plaistow
I've been prepping an area where I'm putting a shelterlogic garage to store my new tractor. Doing some research on what people use for floors on these (was thinking just gravel?) and how critical it is for them to be level as the area has a tiny front to back slope I dont feel like having to level.
For $275 it will be a good experiment to see if it survives a NH winter.
Tractor Dell
Kubota BX23S
Jun 13, 2017
122
Central PA
Gravel would probably be good. Just some kind of stone to keep the mud at bay. As for the slight front to back slope, as long as it isn't too bad, it may help it drain a bit better. Especially if you have enough stone to keep the floor above the level of the outside area. My 2 cents. :)
tiktock
225
Plaistow
If i were to truly level the area, I'd probably have to correct a 20" or so drop over a 20' long area. My instinct was to install the shelter as close to level as possible by raising the back corners a bit, then just building a little frame inside almost like a raised bed garden and filling it with stone in a way that at very least cuts down on the slight incline by putting more stone at the back than the front. I thought about using pallets or something to build a floor but gravel seems easier and less work.
Howling
BX2370
Feb 5, 2016
217
10
Ayer, MA
Check ROPS height vs rolled up door. Originally had to lift the rolled door over my BX ROPS going in and out. Last year I raised the whole shelterlogic on 2 levels of PT 4x4. Now the rolled door just drags over the ROPS.
I do clear the snow off the shelterlogic after it storm. At 2-1/2 years mine is starting to tear where the cover goes over the bars.
groomerbuck
137
Palmerton, Pennsylvania,
Ive been super busy with work the past 3months and FINALLY (kinda sorta not really) caught up so i figured id take today off and make it a 3day weekend so i could tinker around the house with some projects. I needed to clean the under side of my mower and figured id make a set of axels so i could store the mmm in the basement this winter. The material used was 1-1/4”o.d,3/4”i.d, 1/4” wall DOM tubing. I then cut the heads off 3/4” bolts and welded the shoulder of them inside the tubing. The wheels i used are 12”x3” solids. I saw them on some sort of cart at work that someone through out on our scrap pile a couple months back so i figured free is for me!!
tiktock
225
Plaistow
Yes I'm quite sure I'll need the ROPS folded to get in there but planned to see what I could do to work around it if possible.
mpham
B 2650 cab
Nov 15, 2016
152
Massachusetts
It started with, I should wax the hood while the weather is still good. Then it was, My god look at those windows. The floor could use a vacuum job, the seat and floor could use a bath. While I have the bucket the wheels are awful dirty, hey what’s all that soot on the loader arms! Lol! 2 1/2 hours later.
tiktock
225
Plaistow
I put down an inner frame and a bunch of stone that will make the base for the shelter I'll store the new tractor in for winter.
The shelter will fit outside the frame.
twomany
B7200
Jul 10, 2017
793
138
Vermont
I hauled the wood splitter up out from under the barn and out back.
Split up the three stacks of "rounds" that just seemed to slip under the radar.
Then hitched in the garden trailer and brought all the "uglies" up near the back door.
I like to get those burned up and out of the way early.
47 degrees out doors, The fire feels good....
7,075
Very nice - would like to see a picture when done!
9,456
Question?
What does one do with a tractor when their yard is smaller than the tractor?
How do you even turn it around? :confused:
