tiktock
225
Plaistow
I put 2 hours onto my brand new BX1880 learning the basics of operating the FEL while digging into some root filled compost and debris. Had a blast, got in the mud a bit and made a mess...felt like a little kid in a bigger sandbox.
hockeystewey
2017 BX1880 w FEL, 54"MMM, 2019 BX2816 50 " snowblower
Dec 12, 2017
114
NY
It was muggy and buggy today so before I mowed the lawn I mounted magnets on my Ryobi 18V battery operated fan - kept me cool and kept the bugs out of my face!
Hey Jeep.....where did you get those nice big round magnets you used ?? I like your idea!!!
thx
Polishammer
37
Atlanta, GA
Polishammer, what's the "rest of the story"?
Simple operator error.
I have not seen it first hand when it happen, just after the fact, but the user parked the tractor on the side slope to use the backhoe. The operator was wearing shorts and somehow the boom swing lever got stuck in operators shorts leg while she was moving around the tractor and the boom swung from one side to the other causing the tractor to flip throwing her off of the machine.
I was hoping that my BX would be enough to flip it back, but it would just spin. Not enough weight even with my 200lb ass. Had to bring my truck to make it work.
Fortunately no one was hurt, just bruised egos. We flipped it, let it sit for few hours, checked and topped of all the fluids and it fired right up. No damage whatsoever.
6,900
That gal was lucky! There's a couple of lessons there. One, don't use a tractor sideways on an embankment. Two, what you wear while around machinery can have an effect on your safety. Got to be thinking about it all the time!!
4,256
PH I was just wondering if she had to change her shorts after wards,,, I know I would have to :D
mic214
Kubota LX2610 W/cab brushhog, box blade & pallet forks
May 11, 2014
50
Colorado
I borrowed a bucket with teeth from work and today I took out about 30+ stumps around the property…
4,256
Im sitting here watching the OL use my tractor,, still not allowed to drive ( not that I havent slipped into the truck a couple times), but she says not untill Doc says you can use the tractor !!!!! grrrrrrrrrrrrrr
bearbait
Dec 9, 2011
4,118
884
New Glasgow Canada
Be patient skeets, it'll all just be a bad memory soon brother.
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
well just for giggles.... took the B8200 i picked up out & mowed the yard with it.
my usual mowing is with the Hustler HyperDrive, thought this would be a good time to play/compare the 2.
mowed about 5 acres. took me about 3hrs vs 2hrs on the Hustler.
only used about a gallon of diesel vs 4 gallons of gas. that was a plus!
Grass looks pretty good. the blades on the deck were unknown, but they cut it down just fine.
surprised me how tight the 8200 actually turns! its not a zero like my Hustler.. but it was very manageable around the trees & such.
picked this 8200 up because the price said "buy me".... might start cycling it in/out of the grass mowing rotation or heaven help me.... stick my wife on it & have both of us mowing again.
last time we did that : she hit THE HOUSE with the tractor. :eek:
mic214
May 11, 2014
50
Colorado
I have digging up stumps around the hacienda for the past couple of days. Today I put my rig to work picking them all up and dumping them into a large ditch at the upper end of our property.
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
I have a lot of pine roots above ground making grass cutting a real pain so I embarked on pulling them up. About 5 years ago I took an old chain on my saw and cut them off at ground level.
Now they are back 3 and 4 inches above the ground. Took my tater plow dropped it behind them eased forward and lifted at same time, worked great. Then took strap with loop son each end and wrapped around the exposed roots and pulled them up using front bucket.
It will take another day to finish up and fill in with some dirt but no more roots in my way of grass cutting.
fj40dave
Sep 24, 2009
425
257
Yelm, WA
I got my mower thingie delivered today while I was at work......thanks to my Brother In Law!
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
Hey.... It's on the wrong end of the tractor! ;)
Besides mowing some, I use my front loader to move just about everything over 50 pounds. (Three low Back surgeries)
fj40dave
Sep 24, 2009
425
257
Yelm, WA
I hear ya on moving stuff!
