Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
A close shave as they say . . .
I moved 22 bags of cement up to the pour site (same as the stone) 6 bags at a time. I was going to boom the mixer up there too, but we bulled it up a make shift ramp. Now I need another 25 bags to finish the retaining wall then pull the forms and back fill with more #2 to be ready for the stone on the face side. I am in awe of the work this tractor does for 15hp. I did have to add a cup of oil, but the coolant and hydraulic was fine. Added 3 gal. of diesel today too. And I'm very happy I added those 5 suitcase weights . . .
tiktock
225
Plaistow
I wanted a ball hitch option for my BX and didnt feel like using the 3PH or paying $100 for one.
I found one of these at Harbor Freight:
https://www.harborfreight.com/3500-lbs-step-bumper-receiver-69673.html
Flipped it over and the back holes line up perfectly, just need to be reamed out another 1/8"
Front holes need to be drilled new, not a big deal with a drill press (I used a milling machine) Uses the original screws which were long enough. I bolted right through the original drawbar so I don't lose it.
A quick spray and I'm in action. A 4" lowered hitch flipped over seems to level my brush trailer acceptably and I'm a happy camper.
Total cost like $25 if I include the paint.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
Looks nice!
I have a draw bar for my 3 point with a 2" ball. Nice thing about having it on the three point is that you can back up under the hitch of what you want to tow and raise the 3 point up under it. No lifting.
3,216
Nice, clean installation! Don't you just love it when a plan comes together?:)
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
I use my universal QA forklift frame on the front end, with the forks off. The Titan QA frame has a built in receiver so quick and easy to pop a ball in there. I always have something on the rear end so have yet to use it to pull a trailer.
David Page
Jun 25, 2013
393
84
Dexter, ME
Today I pulled trees out closer to my woods roads so that I can cut in into firewood. I have a ROPS that I need to put on it but with taking a vacation were way behind on my carpentry jobs and our own stuff. So yes a tree snubbed up and the front end climbed a lot higher than I wanted be I got the clutch in. Maybe before snw flies I will find time!
motorhead
May 17, 2012
441
42
Atascadero
I know of two guys, one a Doctor that lost their lives on a tractor because of no ROPS. Hope you get it installed. Just a suggestion....
motorhead
May 17, 2012
441
42
Atascadero
Today I put a new 625ca 51R battery in my 2009 B3200. The tractor had the original 410ca battery in it and it was 10 years old.
Did a whole bunch of moving stuff around with my B3200 today. I have a set of forks that attach to the front bucket and I moved an old 400 pound Onan generator with the forks. I used the draw bar in back with a 2" ball on it to move my wood splitter around. All this was to get my restored 1955 VW bug out of my barn because I am getting it ready to sell it. I have owned the bug since 1979 and restored it about 28 years ago.
Got to say too that converting to the alternator on my B3200 was the best thing I have done to it. With the new battery and just above idle, I get 14.4 volts and when first checked, the alternator was pushing 9 amps into the battery. Sure cranks faster with the 625ca battery.
jnldr
L2800
Mar 12, 2010
Knox TN
Sweet bug, what is one of those worth?
huntfishquest.com
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
I needed a holder upper (for a steel rack I'm fabricating for a neighbors 3.4 KW grid tie solar array)while I changed the rigging on my shops overhead chain fall trolley, the L3301 worked perfectly for this as usual.
motorhead
May 17, 2012
441
42
Atascadero
huntfishquest.com
It is worth a bit North of $25,000. It is a "European Deluxe" model and was originally delivered to Holland. Not a US spec car. It has the semaphores instead of blinkers, came with KM speedo and cloth interior. I added Porsche 356A drum brakes all the way around, 9" drums stock VW, 11" Drums Porsche.
It has a rebuilt 1965 Fully synchronized trans and I built an OLD School 1700 CC engine with forged pistons and Engle 100 cam. Carb is a Zenith 32 NDIX 2 barrel carb jetted for single carb applications. It came off of a mid 60's Porsche.
One thing is that it is a matching numbers car. I have the original 1192 cc, 36 hp engine that is apart but it is the original engine.
Jblac197
L3800, bush hog, tiller snowblower
Aug 21, 2018
73
Hibbing
My new L3901DT arrived yesterday morning g. Afterwards, I checked all the fluids and put almost 5 hours on it bush hogging and playing!!
Straight to bush hogging on a new engine???
Sent from my SAMSUNG-SGH-I337 using Tapatalk
motorhead
May 17, 2012
441
42
Atascadero
Why Not? Diesels like to be worked. When NEW, you vary speeds. You don't want to run them at full load but I am sure with a tractor that big, bush hogging isn't running it at near full load. I'd do an oil & filter change at 10-20 hours.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
Unfortunately, I listed mine for sale. :eek: :(
Jblac197
Aug 21, 2018
73
Hibbing
True.
tiktock
225
Plaistow
I attached a chain box today...just an ammo box painted Kubota orange attached using the slow moving vehicle sign bracket. Fits all my chains and looks good.
I also had a great Piranha Tooth Bar moment. Jabbed the teeth into a really stuck fence post and with a curl, it slid right out:
motorhead
May 17, 2012
441
42
Atascadero
That BOX came out nice. Pull the chain out of there, add some ICE and add your favorite beverage!
Jblac197
Aug 21, 2018
73
Hibbing
That's a good idea with the ammo box. Might have to steal your idea. The little plastic tool box it came with is too little for anything other than some spare pins
