4,224
Not a Kubota, but fired up the old timer today and ran everything up to operating temperature.
Also verified that it will fit on that side of garage.....sshhh, don’t tell my wife.....:geek:
I had a grandfather-in-law who was the Minneapolis-Moline dealer in Bay City, Tx for decades. He had ”immigrated” to Tx from Minnesota as a child before the Great Depression and recalled thinking they were RICH with all the rice-farms in the area.... (rice being considered a staple in his family).
I always remembered Mr. Denn fondly whenever I think of a MM machine. Thanks for the pic! Enjoy that old beast.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
Well it hasn't rained for a couple of days so this was a good opportunity to regrade about 200' of my gravel driveway. After I ripped out the juniper bed and replaced it with new plantings / mulch / edging I saw I had a drainage problem. This section of the driveway was tilted towards the new bed. When it rained the edging didn't allow runoff. I really didn't want it to drain on that side anyway. So. . .
I got a real chance to use my new top n tilt with the box and back blades. First I experimented with ripping. Fortunately because of the recent rain the rippers made short work of loosening everything. Unfortunately because of the recent rain the material was really heavy.
Then I used the back blade to move the material from one side to the other. Again the top n tilt made life much easier in setting the tilt of the blade. I ended up moving about 5-6" of material from the high side to the low side. As I was doing it I realized the mulch edging was only 3" high so I had to taper down to it starting about 12" away. That was manual raking work. It would have been easier if it wasn't 90 degrees.
All in all I'm pleased with the results but I'm going to have to bring in some material to dress it out. We will see in the next rain how it does.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,735
4,566
PEI Canada
Mowed 6.5 acres and need to pull deck off to give it a good cleaning, sharpen the blades and fresh coat of wax underneath.
Bmyers
May 27, 2019
3,636
4,939
Southern Illinois
Worked on the rotary mower. Noticed some bolts missing from the rear guard, replaced those and went around and tightened all the other bolts.
BX23S
2022 Kubota L3901 FEL, BH, GRAPPLE, PALLET FORK, SNOW PLOW and Hard Canopy
Sep 1, 2018
70
41
ID
Moved several tons of top soil throughout the property. I love this machine!
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
Got some shop time today to install my 2nd and 3rd rear remotes.
Gotta call salesman Monday and figure out what else I need, I ran out of slots for the levers.
I think I remember seeing another bracket where those two bolts are in the brochure. He’ll take care of me, not too worried about it.
7,346
Maybe not but that ole MM has sorta become family here. ;)
Well thanks, Magic.;)
I haven't driven that routinely in 30 years, but started 51 years ago.
We complain here on OTT sometimes about safety features, switches, etc.
That Old Fart has nothing. Given the narrow front end (NFE) and loader, it's prone to be a little dicey any day, and "it" could happen real quick.
There's probably 73 different ways that could kill you. You need to pay attention operating it.
While it's been years, I was taught safety by my Grandfather and Father...hoping I retained enough of that.
I had several school classmates severely hurt or killed in farm accidents.
Whether Darwinian or not would be debatable.
I've often said if there were more people like that, there'd be less people like that.....
Honestly, sometimes it does give you an appreciation of at least some of the modern safety features..... ;)
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
I believe I figured this out on my own. The older MX kit was ordered. I need kit MX6883, MX8453 was ordered. This is what it should look like. And I will probably be cutting my 1st lever down a touch.
jabloomf1230
B 3200
Sep 28, 2014
125
34
Voorheesville, NY
I went to put my backhoe on after taking my landplane off. When I went to line up the BH to the back of the tractor, I couldn't move the stabilizers independently. Both levers moved in unison. After thinking about this for awhile, I consulted the gods of Youtube:
It might be helpful to others.
johnjk
Apr 13, 2017
1,809
2,200
West Mansfield, OH
Mowed with the B1700 on Saturday and noticed that the belt on the mower deck was coming apart. I have a new belt on hand. Will change it this week and pull the blades to put a quick edge back on them since I’ve hit a few rocks this spring
aaluck
Oct 9, 2019
1,005
844
Snowdoun, AL
Needed to dig a narrow trench to bury some direct burial cable. Made a 'trencher' out of an old bush hog blade and my one row plow frame. This thing works like a champ. The angle of the BH blade rolls the soil perfectly and you have a great little trench.
B737
LX3310
Jun 9, 2019
2,022
2,205
turned 3 acres of this...
into this... mmmmmmmm :)
Reactions: 7 users
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I love it except........
Don't put your chainsaw in the bucket and forget that it is there because.....Bad things can happen. :rolleyes: :(
BAP
Dec 31, 2012
3,183
1,303
Are you speaking from experience?
David Page
Jun 25, 2013
402
90
Dexter, ME
Up here rocks work their way to the surface because of frost, so I also wait till after a couple mowings before sharpening blades.
shootem604
Apr 23, 2018
874
British Columbia
I have been using my bush hog behind the L245 to keep the grass down while I wait for parts for my Stiga Park Pro lawnmower. Sure isn't the same finish!
aaluck
Oct 9, 2019
1,005
844
Snowdoun, AL
Started a project that’s kicking my butt. Been wanting to put riprap in drainage ditch for a while and pulled the trigger. Before the comments I cannot stand seeing an open culvert. I’ll start the other side tomorrow.
Reactions: 6 users
