I need to get the *#$!!@#$ Hydraulic Control Valve (CIRCLED) off to replace the o-rings. After having to remove roll bar, seat, fenders, on and on and on, I was able to remove the 2 Hydraulic fluid lines and could get to the only other thing that holds it in place besides the bolts. After many tries I finally was able to remove the worlds most difficult Spring Pin(160) and the super easy to remove Joint Pin(170) from the Hydraulic Lever Boss(150). So the only things holding this stupid thing on should be two bolts, However, even though pins 160 and 170 are removed this thing will still not come off. I have sprayed penetrating oil on part 150 but it will not budge.. Is there some super secret trick?? PLEASE HELP!!
