Please please please help with bx1500! My grass is now 2 feet tall.
O'boy
BX1500
Jul 9, 2020
41
I need to get the *#$!!@#$ Hydraulic Control Valve (CIRCLED) off to replace the o-rings. After having to remove roll bar, seat, fenders, on and on and on, I was able to remove the 2 Hydraulic fluid lines and could get to the only other thing that holds it in place besides the bolts. After many tries I finally was able to remove the worlds most difficult Spring Pin(160) and the super easy to remove Joint Pin(170) from the Hydraulic Lever Boss(150). So the only things holding this stupid thing on should be two bolts, However, even though pins 160 and 170 are removed this thing will still not come off. I have sprayed penetrating oil on part 150 but it will not budge.. Is there some super secret trick?? PLEASE HELP!!
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,346
1,780
Western MT
I don't know about that part, but usually heat is next.
2,919
1,381
Yes, you will have to heat it up to remove it if it's stuck.
5,235
1,017
Cut sleeve #150 lengthwise with an angle grinder. Replace sleeve.
It will likely work even when sleeve cut with the two spring pins through it.
O'boy
BX1500
Jul 9, 2020
41
Here I would just call the mobile service truck and let them come fix it
I would too if we had one! I even called my closes Kubota repair place and they said they didn't know how to take it off and that they could look at and see but they were weeks behind and I don't have a way to transport it to them right now.
O'boy
BX1500
Jul 9, 2020
41
Thanks. The sleeve is only $9 so that is good! Almost everything else I've had to buy for it was $$$
4,899
When you do reassemble, apply Neversieze to the parts 150,160,170,110, and the valve shaft.Rub and smear the NS on . After it works, THEN spray some thick Rustchek ,al over the 'joinery'. The 'trick' is to keep water OUT of those parts. A baby CV 'boot' full of grease would be ideal, though perhaps exteme.
O'boy
BX1500
Jul 9, 2020
41
Good idea. That way the next person that has to do this will have an easier time because I'm not doing it again! :oops:
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
358
89
Canton, MS
When you go back together with it be sure and use some anti seize.
O'boy
BX1500
Jul 9, 2020
41
I GOT IT!! I was able to get some vise-grips in there and clamped them onto the sleeve and held them and worked the lever(120) back and forth until it finally started to move a bit. Slowly it started to move a little and then more and more! Finally it came free!!! Here are the o-rings that were in there and the new ones that are going in. I thought that they were the cause of the leak and now I am pretty sure. Flat crushed and stiff. I guess we will know when I get it cleaned up and put back together!
2,965
I GOT IT!! I was able to get some vise-grips in there and clamped them onto the sleeve and held them and worked the lever(120) back and forth until it finally started to move a bit. Slowly it started to move a little and then more and more! Finally it came free!!! Here are the o-rings that were in there and the new ones that are going in. I thought that they were the cause of the leak and now I am pretty sure. Flat crushed and stiff. I guess we will know when I get it cleaned up and put back together! View attachment 59161
Wow! The difference is unreal! Almost to the point that I would wonder if the replacements are the correct ones.
Just my initial impression as a novice with little o ring knowledge.
O'boy
BX1500
Jul 9, 2020
41
They are Kubota O Rings ordered from Messick's. Correct part numbers on packages so I am gonna assume they are. They are the same diameter but the old ones are flat and these are still round.
2,547
New ones on top, old ones below, I think. I was kinda confused myself for a minute.
O'boy
BX1500
Jul 9, 2020
41
Woo Hoo. New O-Rings in, tractor put back together, no leaks, grass mowed! All is good in the world. Thanks all!
