Wildfire
Very very nice. I'm very impressed!Threw some paint at my B6000e
To hell with your lights...is that a Porsche???????Sorted the lights on the B6000DT - It was a bad connection in the fuse holder
In Utopia when punching 9" holes I have to use a carbide tipped rock auger on my 640 Ford. Doesn't stop there. Got an 8' stinger coming off the rear with 85lbs on the end for added down thrust.L3800 and I attempted to use a 9 inch inch auger on north central idaho frozen ground... Took 30 minutes to get 2 inches. Not very effective. I suppose I'll be waiting until spring to build my 18x18' wood shed after all. I did get the building markers all laid out, though.
Don't forget the beer and a few bud's, excuse the pun.Im thinking a case of powder would be a lot faster,,, and more fun too
It is a 1995 Porsche 993 Carrera 4 - I need something to go to the local Kubota dealer - Good job I only need small parts!!To hell with your lights...is that a Porsche???????
Thanks for posting, I know what I'll be doing next week.Didn't do anything on the Kubota today. It was -11 F this morning with 10-15 mph wind. However it is warm inside so I thought I would get around to posting some pictures of the Sight Guage I made for the bucket to indicate level. Pretty simple, used a Hound Joint, a piece of smooth rod and pipe. Welded a long nut to the rod, drilled a hole in the quick coupler, threaded the Hound Joint into the nut using a jam nut, slid it in the pipe and bolted that to the loader where the cylinder attaches. I notched the end of the pipe at the top to see the rod as it is getting close to level. With the threaded nut and joint, I can fine tune the adjustment as needed. Works slick and makes it much easier finding level.
Well, I didn't do much either. We have no snow here in the West.Thanks for posting, I know what I'll be doing next week.
