Spring came off...now my T1880 will not go forward or backward...
NC Scout
Kubota T1880, Kubota BX2200, Kubota B7800
Sep 11, 2020
North Carolina
I have the spring, but do not know where it goes. Not sure where I should be looking. Any suggestions appreciated. I am assuming it is the spring that is the problem, or it could have been from something else that occurred at the same time.
5,257
1,043
I looked through parts illustrations and the only external spring I could see was associated with the brake pedal.
However, likely linkage has become disconnected under your tractor and removing the mower deck for a good look is suggested.
2,063
Cathy,
Good point. Will take a couple pictures today.
cheers
Lenny
But you have to get over 5 posts before you can post the pictures.
Just post 3-4 more times with a few kind words
3,186
1,604
It would be your HST belt tensioner spring, #140 in PDF below.
NC Scout
Sep 11, 2020
North Carolina
This is very helpful. The spring is exactly like the one in the illustration labeled #210. I can't see where it connects in the photo or wha it connects to. Thank you.
NC Scout
Sep 11, 2020
North Carolina
Kathy, do I attach photos by clicking on the attach files button once I am allowed to post? What file size can the photos be? Sorry for all the questions, just trying to learn my way around the site.
Cheers,
Lenny
5,257
1,043
I marked up Whitetiger's parts illustration for you
The long end of the spring connectsinto a hole in the pivoting lever with the pulley attached.
The other end of the spring clips to something which is not clear to me but if you look closely you should see polished metal from where the spring attached.
5,257
1,043
Cheers,
Lenny
The attach files button is for things like pdf files.
Along the top banner of a post is a spot to click to insert image.
Move your cursor over it and it will tell you what each symbol is for.
NC Scout
Sep 11, 2020
North Carolina
Dave, Thank you so so much. You have been great. I hope to have it back running tomorrow.
This is so helpful. Cheers.
NC Scout
Sep 11, 2020
North Carolina
I jacked it up, removed the wheel and I still can't figure out where this spring attache
I jacked up the tractor, removed the wheel and I still cannot figure out where this spring attaches at the other end. See the pictures...
DrankTheOrangeKoolaid
M6800/M920, Case 780B
Sep 24, 2019
99
34
Alberta
Looking at the parts diagram, I would be following the lever back to the pivot point, and then locate the bolt labeled 070. That should put you close to where the spring attaches.
5,257
1,043
NC Scout
Sep 11, 2020
North Carolina
Thanks Dave,
It may be that the bolt/screw O70 is missing which is why I cannot find an attach point. Sorry about the pix, I am new at uploading. Will try again tomorrow to see if I can find the attach point. Appreciate your help.
3,186
1,604
Thanks Dave,
The spring attaches to the Hydro belt tensioner and a bolt in the LH side frame rail, about halfway between the front and rear tires. It's pretty much straight Left of the tensioner mounting bolt.
