I have the spring, but do not know where it goes. Not sure where I should be looking. Any suggestions appreciated. I am assuming it is the spring that is the problem, or it could have been from something else that occurred at the same time.
But you have to get over 5 posts before you can post the pictures.Cathy,
Good point. Will take a couple pictures today.
cheers
Lenny
It would be your HST belt tensioner spring, #140 in PDF below.I have the spring, but do not know where it goes. Not sure where I should be looking. Any suggestions appreciated. I am assuming it is the spring that is the problem, or it could have been from something else that occurred at the same time.
This is very helpful. The spring is exactly like the one in the illustration labeled #210. I can't see where it connects in the photo or wha it connects to. Thank you.It would be your HST belt tensioner spring, #140 in PDF below.
Kathy, do I attach photos by clicking on the attach files button once I am allowed to post? What file size can the photos be? Sorry for all the questions, just trying to learn my way around the site.But you have to get over 5 posts before you can post the pictures.
Just post 3-4 more times with a few kind words
I marked up Whitetiger's parts illustration for youThis is very helpful. The spring is exactly like the one in the illustration labeled #210. I can't see where it connects in the photo or wha it connects to. Thank you.
The attach files button is for things like pdf files.Kathy, do I attach photos by clicking on the attach files button once I am allowed to post? What file size can the photos be? Sorry for all the questions, just trying to learn my way around the site.
Cheers,
Lenny
Dave, Thank you so so much. You have been great. I hope to have it back running tomorrow.I marked up Whitetiger's parts illustration for you
The long end of the spring connectsinto a hole in the pivoting lever with the pulley attached.
The other end of the spring clips to something which is not clear to me but if you look closely you should see polished metal from where the spring attached.
I jacked up the tractor, removed the wheel and I still cannot figure out where this spring attaches at the other end. See the pictures...I marked up Whitetiger's parts illustration for you
Your photos are too small to be of much use. I tried expanding them but there is little detail.I jacked it up, removed the wheel and I still can't figure out where this spring attache
I jacked up the tractor, removed the wheel and I still cannot figure out where this spring attaches at the other end. See the pictures... View attachment 48440 View attachment 48441 View attachment 48442
Thanks Dave,Looking at the parts diagram, I would be following the lever back to the pivot point, and then locate the bolt labeled 070. That should put you close to where the spring attaches.
The spring attaches to the Hydro belt tensioner and a bolt in the LH side frame rail, about halfway between the front and rear tires. It's pretty much straight Left of the tensioner mounting bolt.Thanks Dave,
It may be that the bolt/screw O70 is missing which is why I cannot find an attach point. Sorry about the pix, I am new at uploading. Will try again tomorrow to see if I can find the attach point. Appreciate your help.
