NWAZL3560
L3560, LA805 loader, BH77 backhoe, rock bucket, box blade, pallet forks
Jun 11, 2018
128
58
Mesquite, NV
Cool pic!
Just curious, why say NW AZ if you are from SE NV? (Mesquite Nevada)
Inquiring minds want to know.:)
Our house is in Mesquite, but the tractor is on our 10 acre rural property in Scenic AZ, just about 7 miles away!
Ping
BX2370-1
Dec 25, 2018
336
301
Troy, Ohio
Took 'Jaws' out for a test drive. Cleaned up a downed limb from a recent storm. This EA Wicked grapple is a beast and there is a learning curve involved. At first, I would grab maybe 1 branch. By the end of the evening, I was able to grab multiple pieces on a consistent basis. For the smaller, bulkier stuff, dropping into the pile like a scrap grapple or the 'teddy bear plucking quarter eater' at Chucky Cheese seemed to work best. The large limb was all my BX could do to just get it off the ground! After chunking it in half, no problem at all with the weight.
Regards.
BXHoosier
BX24
Jan 21, 2018
497
591
Indiana
Been painting some pieces for the BX. Tool box, pallet forks, and rear hydraulic valve.
SidecarFlip
Banned
562
I'm about to embark on taking the front wheel assist prop shaft out of my M9000 open station and replacing the coupling. It's getting sloppy and needs renewed. I hear it's not a big deal other than laying on a creeper and working overhead.. Got the couplings and roll pins from my dealer last week. Due to the C19 stuff, they delivered them to the farm.
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
Well I used my 10 foot pull type box blade with my L6060 today. First time, had only used on recently sold JD with 50% more hp and at least that much more weight. Had no problems pulling it moving dirt and cutting some to get it level. A full ten foot wide box blade...mind you as my tractor expert said, just take a little cut..
BigG
Sep 14, 2018
1,951
774
West Central,FL
Pictures?
pokey1416
Jun 24, 2020
568
855
SW Michigan
I watched it being unloaded yesterday and parked it in the yard. Finally here! Oh, I also measured all of the dimensions to make sure it fits under a 9' high OH door. Would have been a shame to have to raise the garage a couple inches. And, the wife came out and took her first look "I thought it would be bigger" she said! Dealer experience was great and I really am liking this tractor. :)
Reactions: 8 users
Bmyers
May 27, 2019
3,499
4,447
Southern Illinois
Your wife knows how to hurt a man......" "I thought it would be bigger" she said! "
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
The correct question then would be "how do you know"?? :oops:
That is a very nice machine no matter how small it is. ;)
pokey1416
Jun 24, 2020
568
855
SW Michigan
Boy I sure set myself up for that one! The wife has been laughing on this for 2-days...I might have to put my foot in my mouth more often :p
shootem604
Apr 23, 2018
874
British Columbia
Used my forks to unload some building materials. Also handy to lift the fifth wheel hitch in and out of the truck box during camping season - I can't believe I used to just pick it up and throw it in there.
bx tractorjoe
Jun 3, 2020
258
141
loxahatchee flordia
My new 60 inch finish mower was delivered today at 11 am.. still in the crate... greased everything checked gear box oil and fine tuned the 3 point linkages to fit correctly..
by 1 I was mowing.. by 1.02 I was smelling rubber and saw smoke coming from it.. after adjusting the belt tensioner, was to tight mowed the lawn..
Bit of a learning curve from mowing with my old bx23s to this it cuts very nice.. and I didn't take out the fence or any trees in the tight spots..
My tractor was delivered on the 10th and the mower was on backorder..
The bx was definitely better for tight spots and mowing close to my 600 or so feet of fence but it's nice to be able to back under trees and not hit branches with the canopy or rops. That and I have a 36 inch scag for the fence and tight spots
BigG
Sep 14, 2018
1,951
774
West Central,FL
I was just at a dealer today looking at the grooming mowers. Did you think about a 72 inch mower so that you trim better? That is the direction that I am leaning for my L2501.
bx tractorjoe
Jun 3, 2020
258
141
loxahatchee flordia
Yes.. after I ordered the 60 inch.. doh! I was going to pay the 600 some difference for the 72 but it was another 3 week wait.. pretty sure I'm stuck with this one now.. but there is a nice l245 with a 60 inch mmm for a few hundred more then I paid for just this 60 inch mower that I'm seriously considering buying but the seller hasn't responded to my messages.. humm
nocash247
B7200
Jul 13, 2020
35
14
RI
Changed my hydraulic fluid and filter, installed a new fuel filter (discovered the previous owner removed it and ran it without one), and installed a new shift boot (the source of water in my trans).
